Anyone tested the results for gpt4 vs chatgpt? Is the weird hard cap of 10 result’s still the case?
You can try overriding our prompt which is “unless told otherwise, generate 12 tracks” ![]()
Is that an actual thing? If yes then why
Why wouldn’t it be? We default to that limit because it takes a while to generate and time is money, and around an hour of music is a good bite-sized chunk.
Also, if you want longer playlists, you can use DJ Stetch or DJ Gemini ![]()
