How to get ChatGPT generated playlists into Plexamp?
Asking ChatGPT directly to create playlists results in a much better list of tracks than using Sonic Sage (I would be interested to know why…) – so I’m wondering, is there some way to take a text list of songs and import it into Plexamp?
Solved! See this thread.
Because we limit the number of tracks it generates. You should be able to override by telling it what you’re looking for.
I agree with you that the numbers of results with Sonic Sage could be very limited.
If i prompt for the 50 best rock songs ever, i just got 7 tracks. I can assure that i have a pretty confortable collection of rock songs, certainly including more that 100 or maybe even 300 (if we go further) of the best rock songs.
Also, i am under the impression that a few months ago i would have better results than now.
I do really like this feature, but i would like it more if it can fullfill an evening with songs from a prompt, maybe go up to 30 songs ?
(I know DJs can help here, but that is not the point :))
if you guys don’t have a tidal linked, this is expected and has been explained many times.
with programming, sure. you could check plexamp logs for what API it’s using to match into tidal.
Hmm, afaik the Plexamp device token should work .
Edit: Try passing X-Plex-Product: Plexamp
