great work guys
Its great to have HULU back any idea when we will be able to choose the hi-res as the default i know there is a lot going on but i am just curious
as i still find myself having to go directly to there site for the better quality.
keep up the great work guys
If you log in to Hulu using Safari on the computer you’re running Plex on, you should be able to set your defaults there & have them reflected in Plex’s Hulu plug-in. We’re working on a way of allowing you to set these things inside Plex :slight_smile:
ok so as long as i set the hi-res vid in hulu prefs plex will continue to use these settings? and eventually plex itself will let me choose ?
Yes - Plex uses WebKit to access sites & capture the videos, which shares cookies & login information with Safari. We're working on a way for you to change these settings directly from Plex, but for now using Safari is a good workaround :)
