green artifact during streaming [x265 10bit] [AAC 5.1] [MKV]
If I open the file from the file manager I can play it normally using mx player. But it wont stream without having green artifact and stuttering.
I tried to disable direct play and all other options. I also tried optimizing and syncing (converting to different format) in hopes to make it work but always the same result. Video plays with audio but badly stutters with green artifact.
Devices tried: S7, ipad air 2, PC (all same results)
Below is file details. Is there a way to file those files?
               Source file MediaInfo
Complete name
Format : Matroska
Format version : Version 4 / Version 2
File size : 196 MiB
Duration : 22mn 36s
Overall bit rate : 1 209 Kbps
Encoded date : UTC 2016-02-29 04:43:35
Writing application : mkvmerge v8.4.0 (‘A better way to fly’) 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
DURATION : 00:22:31.976000000
NUMBER_OF_FRAMES : 800
NUMBER_OF_BYTES : 2605348
_STATISTICS_WRITING_APP : mkvmerge v8.4.0 (‘A better way to fly’) 64bit
_STATISTICS_WRITING_DATE_UTC : 2016-02-29 04:43:35
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 22mn 36s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Writing library : x265 1.7+497-975352b2c022:[Windows][GCC 5.2.0][64 bit] 10bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=20 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=0 / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.30 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / rc=2 / pass / bitrate=992 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 22mn 36s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz / 24.0 KHz
Compression mode : Lossy
Delay relative to video : 40ms
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Language : English
Default : No
Forced : No
There is a bug in the current PMS release on the Shield so that when transcoding 10-bit video (either H265 or H264) you get those green artifacts. We are aware of the issue and hope to have a fix in a future PMS update.
thank you sir. keep up the good work!
there is also a bug where in “photo” you can only view Thumbnail you cannot see any photo’s you click on it’s stays black with like a camera icon on it…
I am not aware of this issue. Is there a thread about this?
i haven’t seen a thread about it ..
here is what the pictures looks like
and this is what it does when we click on it
Can you start a new thread with more details?
Is this on the Shield PMS? What version.
Does it work on other clients?
Provide the log from the client app. https://support.plex.tv/hc/en-us/articles/201573117-Android-and-GoogleTV-Logs
it’s done
I know you’re aware of this plex but words like ‘hope to’ and ‘future’ seem to be kicking it into the long grass! Plex website is full of promises to play 4k hevc files, mentions transcoding if incompatible, but neglects to highlight this issue with 10 bit files not playing and it leaves customers feeling conned
It’s nice that acknowledge it, but we were told you (Plex) were aware and that a fix would be done months ago… And that’s not on Nvidia’s shoulders like external storage apparently is.
Month later. Still running into this issue. Has there been any steps taken to fix it? When can we expect a new release with the issue addressed?
Sorry guys, no news. We are still looking into the issue.
As in… Don’t know what the issue is yet?
As in the transcoder is the HW transcoder in the Shield, which we don’t control. Looking to verify and look for solution.
I’ve noticed every once in awhile if I try some of the HEVC files, they’ll work 5% of the time on my AppleTV or XBOX ONE. Of course the same file usually doesn’t work the next time I try it, but it does randomly work. Not sure if that helps, but any info I can share to help get this sorted.
The same movies work just fine in KODI playing directly from Shield. If the problem was only from the transcoder, the movies should play just fine in Direct Play, and they don’t.
Not so sure. Playback in Kodi is “decoding”, while transcoding required re-encoding. Also, Kodi uses its own media playback engine, so it’s probably completely different.
^^ correct. If you can get the file to direct play in something that supports H265 10-bit, like the Plex for Android app on the Shield, you won’t see these artifacts. It only happens when transcoder down to H264.
i wonder why we ever need to transcode any file? mx player with extra codecs can play any file. i wonder why plex on tv doesnt allow such features.
If your client supports the file format/codecs you don’t need to transcode. If you’re using a client limited in terms of codecs support, like iOS/tvOS devices, then your server has to transcode the files so they’re playable on that device.
