Is there a way to group libraries together? I have my TV shows broken into A-E, F-K, and so on due to the volume of the shows I have. However, there are some times that I want to go A-Z. I know I could create a TV Shows ALL library but that would create duplicates, correct?
It is recommended to do this in media storage, if you have a lot of tv shows.
However, within Plex, you should simply add all those ‘letter folders’ into one library.
If you edit your library, go to the ‘Add Folders’ tab, you can add several locations.
