Guide channel numbers missing and other guide display anomalies
Server Version#:
Player Version#: 1.45.0.3013-1676042f
Tuner Make/Model: Silicon Dust HD Homerun
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name:
When opening the guide the channel numbers are missing, only the channel icon is displayed. Some of the shows display incorrectly (movie is shown for 1 hour when it is 2 hours long) and often duplicated. If you select a day in the future and a time then the channel names disappear completely. If you scroll to the left then some of the channel names reappear but will disappear again when you start scrolling to the right.
Channel number missing
Change day to view and channel icons disappear
Scroll right and some channel icons appear.
If go back to a previous version all works as expected.
Uninstalled 1.45 and installed 1.39.1.2763-300bb607. Guide presents itself as expected except the channel logos are missing. Channel numbers listed and don’t see other anomalies in the display of shows. Guide was working correctly in version 1.39 but since the upgrade to version 1.45 guide has exhibited strange behaviour and incorrect/missing data. Anyone else experiencing this?
Just installed version 1.46.1.3056-ab91bdc0 and the guide shows the channel logos when switching days. Still has channel numbers missing (unless you hover mouse over logo) and display anomalies as you scroll right through the times.
You can see in the screen shot below that the show runs from 8 - 10 but it shows it at 8:30. The show prior to it is 2 hours and it shows it as a half-hour.
Some slight improvement but still incorrect behaviour.
