Guide displays incorrectly when advancing to new day
Server Version#: 1.26.2.5797
Player Version#: 1.52.1.3195
Tuner Make/Model: HD Homerun
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: various
When advance to a new day (ie. selecting Sunday when the day is Saturday) causes the guide to display incorrectly.
The ANW is on from 6 to 7 (shows a second entry from 7-8) and then High school football at 7. Rush Hour 2 ends at 7:30 and then Rush Hour 3 starts (not a replay of Rush Hour 2).
Also, channel numbers are missing from the side bar. They only appear if the cursor is on the line.
Looks like will need to revert to version 1.39 where the guide worked correctly as the WAF is going down quickly.
This has been fixed already. Please update to the latest beta release of Plex server.
I have upgraded to Server version 1.28.2.6106 and Windows player version 1.52.1.3195. These are the latest versions I see in the download section of the Plex site. I still see the problem happening. Are these the latest beta versions you are referring to? If not, where do I download the beta version you reference.
I’m on version 1.28.2.6106 (web player 4.89.1) and I’m seeing the same here on the channel Legend:
The second listing for Cap Car at 2:35 shouldn’t be there, so the Jurassic Games (and everything after it) is showing shifted an hour ahead.
If there was a fix for this, either this hasn’t worked or there’s been a regression.
I finally got a chance to do a few screen captures that shows the problem using server version 1.28.2.6106 and Windows player version 1.52.1.3195. On the guide, Today is Sunday. I select to show Tuesday evening and the following happens.
As you can the show “Unthinkably Good Things” (a 2 hour movie) starts at 6:00 pm which matches the Tivo and Xfinity guides. Plex also shows it starts at 8:00 pm which is incorrect. If I click to move later in time you get the following.
You see that the show mentioned above is still showing a start at 8:00 pm (incorrectly) and that “All for Love” starts at 9:00 pm (which is incorrect, it starts at 8:00 pm per Tivo and Xfinity). Continuing to advance time results in the following.
You see that “aal for Love” now starts at 8:30 pm (still incorrect). Advance time again and you get the following.
“All for Love” now starts at 8:00 pm which is correct. This is issue has existed in the last several versions that I have tried. I only have success with Windows player version 1.39.
