Guide Dates Incorrect
Just installed and configured DVR & Live TV but in the guide all shows show dates 1/1/01 or 2001
Help Please!!
Can you take a screenshot of where you are seeing this
Where are you located? Can you provide your postal code.
Are you using the default guide data or are you using XMLTV
I am located in New Zealand, Postal code 5010 and using the default guide data
Hi Clay! Gracenote guide data in NZ is not great. SO much so that a few years a go someone worked on a 3rd party XMLTV guide feed that still runs today. It is night and day better than the Gracenote feed so I highly recommend you setup the DVR again but this time use this feed https://nzxmltv.com/
I think I used this once before and added the link to the guide setup
http://nzxmltv.github.io/xmltv/guide.xml
Looks about right now
Or should I use this one instead?
https://nzxmltv.com/xmltv/guide.xml
It looks like the github one redirects to the https://nzxmltv.com link. So I suggest using the newer link.
Great thanks, how do I change the Date format for NZ?
Day/Month/Year
