Guide Update Interval - Disable
Server Version#: Version 1.19.4.2935
Tuner Make/Model: HDHomeRun CONNECT
Using XMLTV?: Yes
With the new update & ability to specify the Guide Update Interval, can i disable this so the guide doesn’t update as I have it setup as I have Perform refresh of program guide data. enabled in the scheduled task
I have tried setting it to 0 but it will still update during inconvenient hours.
I will discuss this with the development team
We are looking into this and we will be making changes.
in the meantime you can set the custom interval to a very large number eg 8760 which is 1 year !
Thanks for the update, that sounds great! I will put that temp fix in now
