Hi, I recently had to reset my laptop with the Plex media Server on it. I want to wipe my Plex Server so it doesn’t try to find content that’s no longer there. I’m a Premium member and don’t want to create a new account. How can I start afresh with Plex?
Plex Documentation → Uninstall Plex Media Server
No need to create a new account.
- Stop Plex Media Server if running.
- Uninstall Plex Media Server from PC
- Delete registry key as noted in support document
- Remove the Plex data (not media) directory as noted in support document.
Note: The default location for%LOCALAPPDATA%is c:\Users\your_user_name\AppData\Local. The AppData folder is hidden by default. To make it visible, in Windows Explorer, select the view tab, then check the box next to Hidden Items. - Restart your PC
- Remove old server from list of authorized devices: https://app.plex.tv/desktop/#!/settings/devices/pms
Thanks FordGuy61!
