I have some music concert videos that have multiple angles. Using MKVToolNix I can put all of the videos into one MKV file. Using a player like VLC I can then switch between the different videos angles while the video plays. Is there a similar way to switch between the different video angles using the Plex media players? I’d rather not have separate MKV files for each angle because it defeats the whole purpose of angles and allowing you to switch between the angles.
Multiple angles i.e. several video streams in one file are not supported in Plex.
Ok thanks. If I wanted for support to be added then I can request over in the feature requests correct (knowing full well that it is not guaranteed especially for what is probably a little used feature like this)?
Looks like you already did
I did
