Handling of Files
Does Plex rename files?
Most of mine follow a naming scheme of:
TV Series Title - S01E01 - Episode Name
But some files aren’t like this (yet).
How does Plex handle special episodes from a series? For example, a Christmas special from series 2 - how should I rename that to make sure Plex picks it up properly?
No, Plex will not rename your files.
Have you had a read through this support document yet?
It contains (almost?) everything you need to know about naming TV series for Plex to automatically match them (including how to handle specials).
There’s a similar document for movies:
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
Typically you go to TVDB, look up the show and see if your special is in The Specials Season. If so it’ll have an episode name and number like:
Downton Abbey/
....Season 00/
.......Downton Abbey - S00E105 - The Nekked Episode.xxx
Whatever they have for your episode - name yours the same…
and if The Nekked Episode isn’t there - you hand edit one in…
(give ‘your’ episode a higher number than the others - give it 50 - in case more ‘legal’ specials come along later)
:slight_smile:
So do specials belong in a Season 0 folder?
Does Plex then know when to play them? (IE at the end of season 2?)
Season 00 - technically - but yes.
IF the Special is listed at TVDB is will acquire the Air Date and Play from On Deck when it’s needed. <—Downton Abbey Christmas Specials/etc.
IF the Special is NOT listed - you can set that date in the editor when you’re hand editing and you can put it anywhere you want it.
