Server Version#: Version 1.24.2.4973
Player Version#: 4.62.1
In most cases Plex already uses the best cover, but sometimes when local covers are bad or you want to use an alternative cover you need to use the Poster select which uses way to small images to really judge which Poster is the best (300x300 posters look like 1200x1200 posters so you just can differentiate between them):
I would love to either have an easy way to see the resolution (like a tooltip or so) or to have an easy way to preview the full size images maybe even zoom in to really find the best one.
I second this motion. It would be easy for Plex to have an overlay with the pixel size for each image. It’s impossible to tell if an image is 200 x 200 pixels or 1000 x 1000 pixels. So there’s no way to know how the image will look when it is enlarged if playing Plex on a 70 inch TV monitor.
One observation I’ve made might help you: If I ever imported an image from an album folder into Plex, it’s usually the last image in the series.
