What you need to do is go to the nVidia control panel > under 3d settings > manage 3D settings > Program settings > “Add” - here you select the entire PMS folder (C:\Program Files (x86)\Plex*) - “Select” and you’re done
I’d do a reboot after this and you should be good to go
Saw 8 simultaneous encodes going on the other night (we’ve had more at once but I haven’t caught it in Tautulli). GPU utilization was fluctuating up to 60%.
Decodes still pound the CPU.
I’ve heard zero complaints about quality, stuttering, or overall performance and a couple have shared that it’s quick to add subtitles when selected (versus waiting a few seconds in the past).
One big thing I noticed is sync performance, saw over 30x conversion speed on a tv series sync where it was normally around 6x.
This is interesting, I understood from @OttoKerner, that HW transcoding was not supported with Subtitles, I didn’t think it matter if you were using the onboard GPU or a P2000…
