Hardware Encoding no longer working - all software updated
Server Version#:4.128.1
I am running Plex Server on a Linux Mint system with an AMD A8-7500 and an Nvidia GTX 960. For quite some time after setting it up, and subscribing to Plex Pass to enable hardware encoding, everything was working well. My 1440p and 4K video files would stream at 1080 no problem.
However recently, this stopped working. I would get terrible stuttering no matter the client I used. I logged into my server and updated everything - all drivers, all software, and updated Plex to the newest version. still no luck.
I turned on the system monitor as I stream a higher quality video, and the CPU usage spikes. I checked the settings and I still have Hardware acceleration turned on, and I can even see my GTX 960 in the dashboard under “Hardware Transcoding Device”. But still, the CPU is being tasked with transcoding, and it isn’t even slightly up to the task.
I’m at the end of my rope, google searches aren’t helping. My annual Plex Pass renews in 15 days and I don’t know if it’s worth renewing, as the ONLY feature I use is Hardware Transcoding.
Can anyone help me figure this out?
copied from system reports
System:    Kernel: 5.4.0-177-generic x86_64 bits: 64 compiler: gcc v: 9.4.0 Desktop: Xfce 4.16.0
           tk: Gtk 3.24.20 wm: xfwm4 dm: LightDM Distro: Linux Mint 20.3 Una
           base: Ubuntu 20.04 focal
Machine:   Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis: type: 3
           serial: <filter>
           Mobo: Gigabyte model: F2A68HM-DS2H v: x.x serial: <filter> UEFI: American Megatrends
           v: F2c date: 05/06/2015
CPU:       Topology: Quad Core model: AMD A8-7500 Radeon R7 10 Compute Cores 4C+6G bits: 64
           type: MCP arch: Steamroller rev: 1 L2 cache: 2048 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 23955
           Speed: 2994 MHz min/max: 1400/3000 MHz Core speeds (MHz): 1: 2994 2: 2994 3: 1829
           4: 1695
Graphics:  Device-1: AMD Kaveri [Radeon R7 Graphics] vendor: Gigabyte driver: radeon v: kernel
           bus ID: 00:01.0 chip ID: 1002:1313
           Device-2: NVIDIA GM206 [GeForce GTX 960] vendor: ASUSTeK driver: nvidia v: 535.171.04
           bus ID: 01:00.0 chip ID: 10de:1401
           Display: x11 server: X.Org 1.20.13 driver: ati,nvidia,radeon
           unloaded: fbdev,modesetting,nouveau,vesa resolution: 3840x2160~30Hz
           OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 535.171.04
           direct render: Yes
Audio:     Device-1: AMD Kaveri HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
           bus ID: 00:01.1 chip ID: 1002:1308
           Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
           bus ID: 00:14.2 chip ID: 1022:780d
           Device-3: NVIDIA GM206 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
           v: kernel bus ID: 01:00.1 chip ID: 10de:0fba
           Sound Server: ALSA v: k5.4.0-177-generic
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
           driver: r8169 v: kernel port: d000 bus ID: 02:00.0 chip ID: 10ec:8168
           IF: enp2s0 state: down mac: <filter>
           Device-2: Qualcomm Atheros AR9227 Wireless Network Adapter driver: ath9k v: kernel
           port: d000 bus ID: 03:06.0 chip ID: 168c:002d
           IF: wlp3s6 state: up mac: <filter>
Drives:    Local Storage: total: 3.75 TiB used: 1.24 TiB (33.2%)
           ID-1: /dev/sda vendor: Seagate model: ST4000NC001-1FS168 size: 3.64 TiB speed: 6.0 Gb/s
           serial: <filter>
           ID-2: /dev/sdb vendor: Kingston model: SA400S37120G size: 111.79 GiB speed: 6.0 Gb/s
           serial: <filter>
Partition: ID-1: / size: 108.98 GiB used: 23.40 GiB (21.5%) fs: ext4 dev: /dev/sdb2
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0 chip ID: 1d6b:0002
           Hub: 1-4:3 info: NEC HighSpeed Hub ports: 2 rev: 2.0 chip ID: 0409:005a
           Device-1: 1-4.2:4 info: Primax type: Mouse driver: hid-generic,usbhid rev: 2.0
           chip ID: 0461:4d46
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0 chip ID: 1d6b:0002
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 chip ID: 1d6b:0001
           Device-2: 3-3:2 info: Metadot - Das Keyboard Das Keyboard Model S type: Keyboard,HID
           driver: hid-generic,usbhid rev: 1.1 chip ID: 24f0:0137
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 chip ID: 1d6b:0001
           Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 chip ID: 1d6b:0001
           Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 21.4 C mobo: N/A
           Fan Speeds (RPM): N/A
           GPU: device: nvidia screen: :0.0 temp: 37 C fan: 39% device: radeon temp: 17 C
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/flexiondotorg-nvtop-focal.list
           1: deb http: //ppa.launchpad.net/flexiondotorg/nvtop/ubuntu focal main
           Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
           1: deb https: //mirrors.seas.harvard.edu/linuxmint-packages una main upstream import backport
           2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
           3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
           4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ focal partner
           No active apt repos in: /etc/apt/sources.list.d/plexmediaserver.list
           Active apt repos in: /etc/apt/sources.list.d/surfshark.list
           1: deb https: //ocean.surfshark.com/debian stretch main
Info:      Processes: 218 Uptime: 10m Memory: 6.72 GiB used: 1.97 GiB (29.3%) Init: systemd v: 245
           runlevel: 5 Compilers: gcc: 9.4.0 alt: 9 Client: Unknown python3.8 client inxi: 3.0.38
If I may add to Otto,
This type of problem " It works – then , without reason, stops working " is regrettably “Classic Mint”
I can’t count how many times I’ve sat with the customer (shared desktop) and typed commands (getting correct results) then, without warning, those same commands returned different results as we tested something else.
  1. It’s an ok, light duty, desktop-only / workstation machine for those learning Linux
    AND accept they will need to reinstall Ubuntu, Debian, or a Redhat variant for meaningful Plex server use.
  2. It’s proven time & time again to fail under the load of running a media server
    (everything from inexplicable application termination / bad results to Kernel Panics)
