Hardware transcoding broken on Nvidia Shield [9.0.1]
Server Version#: 1.25.3.5448
Player Version#: 4.75.0
Plex Media Server hardware transcoding is broken on NVIDIA SHIELD TV PRO 2019 in latest 9.0.1:
[Transcode] TPU: hardware transcoding: final decoder: mediacodecndk, final encoder: mediacodecndk
TPU: hardware transcoding: enabled, but no hardware decode accelerator found
TPU: hardware transcoding: final decoder: , final encoder:
[Transcoder] Error while opening decoder for input stream #0:0 : Encoder not found
[Transcode] Transcoder: session dgj5x6it9dnsat6zdkt8ur1h indicated fallback to software decoding
Fresh install after factory defaults.
Yeah, known issue. It’s low priority considering they are still trying to get PMS stable on the latest Android update.
Your option is to hold your breath on when this gets fixed, or downgrade everything. From my experience, you might need to go all the way back to PMS v1.23.x because high resolution HEVC isn’t transcoding correctly in my v1.24 config.
