Hardware transcoding device dropdown list (bug?)
Server Version#: 1.32.5.7210
Player Version#: 4.108.0
SO: Debian 12, Kernel 6.1.0-9-amd64, firmware-non-free
I have my pms running on a VM Proxmox (7.4-13), passingthrough the UHD750 directly to Plex.
Setting up plexmediaserver (1.32.5.7210-77f7f99fa) …
PlexMediaServer install: PlexMediaServer-1.32.5.7210-77f7f99fa - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: render
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /dev/shm (set in Preferences.xml)
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Processor: 11th Gen Intel(R) Core™ i5-11600 @ 2.80GHz
PlexMediaServer install: Intel i915 Hardware: Found
PlexMediaServer install: Nvidia GPU card: Not Found
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.32.5.7210-77f7f99fa - Installation successful. Errors: 0, Warnings: 0
Processing triggers for mailcap (3.70+nmu1) …
After the installation, I can see on the new dropdown list the UHD750 and “Auto” option.
After a reboot, the UHD750 is no longer there. Only “Auto” option.
The HW transcoding is still working, after the reboot.
  1. Just right after installing PMS:
  2. After rebooting:
Regards,
F
Can you get me the logs from after the restart?
Here you go. If you need me to do something for testing, just let me know.
@anon18523487 in case it helps, this is what the PMS server is showing when I run: # lspci -nnv
