Hardware transcoding fail
When I activate hardware transcoding in my PMS and it starts to transcode a movie to a optimised version it fails directly :slight_smile:
I am running it on a Intel Nuc that has a i3 4010U CPU that har support for this.
It runs Windows 10 Pro 1803.
Got a Plex pass just for this feature.
How can I get it to work?
Since its an old haswell CPU it can only DEcode h264 but not encode if I am not mistaken. Dunno if your problem lies here.
But you also didn’t post what type of file it is.
When i read this page: https://support.plex.tv/articles/115002178853-using-hardware-accelerated-streaming/
it should work with my cpu, it is among the Intel Quick Sync Video capable processors: https://ark.intel.com/Search/FeatureFilter?productType=processors&QuickSyncVideo=true
It might, dunno as I am no quicksync expert. Still, it depends on your video file and its codec whether it will work or not,
Ok, but pms should not “crash”, pms should use the software if the hw does not support it.
Mabye got it working by updating my old BIOS to the latest from This year (the old one was from 2014).
Yes, after upgrading the Bios for my Intel Nuc D34010WYK to version 0049 (Latest 20180718) it solved the issue.
Now I have hardware transcoding in my little box :slight_smile:
