Hardware transcoding issue
Hey, thanks for the reply!
I’ve configured the docker settings for Plex but for sanity sake took your advice and spun up the folding docker image and confirmed the GPU is being passed through.
What’s even more infuriating is that I can optimise media using the GPU on Plex, just not live transcoding.
EDIT, to confirm I’m now using:
Plex v1.29.2.6364
Nvidia Drivers v515.86.01 (CUDA 11.x)
Just wanna point out this was a fresh install…not a downgrade !!
I don’t use docker for plex; (the transcode directory is on on SSD)
I did do a downgrade which worked
Sorry, I don’t know what else to sugest, it’s a bummer you didn’t get it working be downgrading.
Fun fact that you can use GPU to optimise the media.
But atleast that kinda’ proves it’s a Plex issue, since function A works and function B does not…
I think the Plex developers have to much focus on bringing us new features no one asked for… and not enough focus on providing more stable software…
When you downgraded, how or where did you see the response code and status message? How long did the Db migration take?
your sure that the card can use CUDA 11 ?
I give a BIG :heart: on that statement…as I told PLEX the same…all this crap games & stream providers…who has asked for this options in a paid software ???
Going on the Nvidia website I can download the latest 525 drivers for the P400 so I can only assume it supports CUDA 11 / 12. I’ve also downgraded to 515 and 470, neither of which have fixed my issue using Plex v1.28 / v1.29 / latest but can passthrough the GPU to folding at home and utilise it no problem as seen above.
When I remove all the Nvidia docker parameters and try going back to CPU HW transcoding that is not working either so something is more fundamental must be wrong.
  • I’ve got a Plex Pass
  • Enabled “Use hardware acceleration when available”
  • Docker has write permissions to /transcode and can see session files being created
    • Tried both RAM and Cache transcoding
  • Used every combination of PMS / Nvidia driver versions
  • Deleted the Codec folder and forced a rescan of all media to redownload
Getting very frustrated with it now, the logs offer no assistance either.
my card uses Nvidia 470 drivers…and it shows i’m using version CUDA 10 as max…
Card are GT 710
Morning Gang :slight_smile:
I needed time off (burning the candle at both ends). I still need more (bad chest cold). Will do the best I can.
  1. As requested: PMS 1.29.2.6364 RPM
  1. Nvidia 470 drivers will work unless you need AV1 decode
  2. Nvidia 515.86.01 is needed for AV1 decode but you then run the risk of the other faults in the transcoder
Where this is still crazier than me –
  1. I have the 525.60.13 drivers installed on Ubuntu server 20.04.5 LTS
  2. Card is a P2200
  3. All my videos are ripped by me (redbox and library are amazing alternative sources)
  4. I CANNOT REPRODUCE THE PROBLEM.
Explanations –
  1. Nvidia CUDA 12.0 driver bug with your specific card (High)
  2. There are issues with PMS - Nvidia CUDA 12.0 ABI. (High)
  3. You have questionable video file quality (meh…)
    (re-encoded by others unknown and busted up… I’ve seen it happen)
  4. You spilled a beverage in the machine and it has a severe hangover :rofl:
PS: I used 515.86.01 (CUDA 11,7) for the longest time. I switched to 12.0 (525.60.13) only to test, fearing the worst. Surprisingly , for me, it works. That having been said – The machine is a pure server (NAS + PMS ONLY ) console mode – No GUI.
For explanation #1 I am curious as to how this is a CUDA 12.0 driver bug when reverting back to CUDA 11.x still sees the issue occur on PMS 1.3x.x. Also if this were a CUDA bug shouldnt I able to replicate the failure to transcode utilizing HW tanscode with ffmpeg with the same videos that fail with PMS? While I understand there are a lot of variables in play but it seems like blaming the CUDA driver version seems to be pushing the blame to NVIDIA when it seems that the issue is with PMS where CUDA 11.x and 12.0 show the same issue on PMS 1.3x.x
Hi there,
I confirm PMS 1.29.2.6364 RPM is working for me on my “questionable” video file… :smile:
But this file has a really low birate and I tried 4k transcoding on Plex web and it really struggle. It works for 20-30s and then start to try buffering (with 1080p transcoding), same file runs fine with transcoding on an iPad.
Also noticed some weird issues after a stall: transcoding service using some CPU and the CIFS process too… weird!
Well, I don’t know what to do but Plex web seems really to suffer a lot…
PS: I also disabled my pre-rolls because it seemed it didn’t like the transition.
@Franck_Ehret
Frank,
I’m writing slowly because I know you don’t read fast :wink: :stuck_out_tongue: lol
Recheck your transcoder settings in Settings - Server - Transcoder - Show Advanced.
Use only Plex/web to verify everything is working. All the players have some form of acceleration which skews results.
Make certain you’re testing using a file with no PGS subtitles (or you’ve manually turned subtitles OFF)
LOGS please?
Do they show CUDA 12 ctx errors?
Also:
:point_up: This #2 on my list. It’s number 2 on the list because, working with others on different projects, those other projects also have the same CUDA 12 problems.
Until such time as anyone can point a smoking gun, BOTH PMS AND NVIDIA are suspect.
I’m not going to debate. This is A OR B problem. Flip a coin.
The root cause must be found and reliably repeated by everyone – which has not happened so far even with my controlled testing last week here in the forum
@ChuckPa
I can downgrade again and run more tests but earlier in the thread I posted these logs that I am showing again
Tue Jan 31 17:05:23 2023
| NVIDIA-SMI 515.76       Driver Version: 515.76       CUDA Version: 11.7     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0 Off |                  N/A |
|  0%   42C    P0    44W / 130W |    295MiB /  6144MiB |      2%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A     49199      C   ...diaserver/Plex Transcoder      291MiB |
Jan 31, 2023 17:05:22.091 [0x7f4b028afb38] ERROR - [Req#8c38/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] Error while decoding stream #0:0: Generic error in an external library
Jan 31, 2023 17:05:22.091 [0x7f4b03acab38] ERROR - [Req#8c39/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] [hevc @ 0x7f038c81bc80] Could not find ref with POC 897
Jan 31, 2023 17:05:22.091 [0x7f4aff7b4b38] ERROR - [Req#8c3a/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] [hevc @ 0x7f038c81bc80] No decoder surfaces left
Jan 31, 2023 17:05:22.092 [0x7f4b02cb5b38] ERROR - [Req#8c3b/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] [hevc @ 0x7f038c81bc80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 31, 2023 17:05:22.092 [0x7f4afe3a3b38] ERROR - [Req#8c3c/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] [hevc @ 0x7f038c81bc80] hardware accelerator failed to decode picture
Jan 31, 2023 17:05:22.092 [0x7f4b02ab2b38] ERROR - [Req#8c3d/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] Error while decoding stream #0:0: Generic error in an external library
Jan 31, 2023 17:05:22.092 [0x7f4b030bbb38] ERROR - [Req#8c3e/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] [hevc @ 0x7f038c81bc80] No decoder surfaces left
Jan 31, 2023 17:05:22.093 [0x7f4aff9b7b38] ERROR - [Req#8c3f/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] [hevc @ 0x7f038c81bc80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 31, 2023 17:05:22.093 [0x7f4afe1a0b38] ERROR - [Req#8c40/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] [hevc @ 0x7f038c81bc80] hardware accelerator failed to decode picture
Jan 31, 2023 17:05:22.093 [0x7f4b0182db38] ERROR - [Req#8c41/Transcode/wii7ye256muu1yabw2bzd27m/3decc53f-5c00-4cfb-a876-249a712a84a3] Error while decoding stream #0:0: Generic error in an external library```
@ChuckPa
Downgraded to the 11.7 CUDA drivers after a kernel update for Fedora just now. Same result 8bit hevc 1080p fails to transcode to h264 1080p. Ive included the last 20 lines of the log file when this happens, can get a bigger segment if needed. Note this is with transcoding the jellyfish file you supplied above.
Files
    /srv/ftp/movies/test/jellyfish-30-mbps-hd-hevc.mkv
Media
    Duration 0:30
    Bitrate 30454 kbps
    Width 1920
    Height 1080
    Aspect Ratio 1.78
    Video Resolution 1080p
    Container MKV
    Video Frame Rate NTSC
    Video Profile main
Part
    Duration 0:30
    File jellyfish-30-mbps-hd-hevc.mkv
    Size 109.03 MB
    Container MKV
    Indexes sd
    Video Profile main
    Codec HEVC
    Bitrate 30454 kbps
    Bit Depth 8
    Chroma Location left
    Chroma Subsampling 4:2:0
    Coded Height 1080
    Coded Width 1920
    Color Range tv
    Frame Rate 29.97 fps
    Height 1080
    Level 4.1
    Profile main
Results
~]$ nvidia-smi; tail -20 /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Media\ Server.log
Mon Feb  6 15:02:27 2023
|                               |                      |               MIG M. |
|  0%   41C    P0    38W / 130W |    119MiB /  6144MiB |      2%      Default |
|                               |                      |                  N/A |
| Processes:        |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A     15464      C   ...diaserver/Plex Transcoder      115MiB |
Feb 06, 2023 15:02:24.273 [0x7f84f89a0b38] ERROR - [Req#ce4/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] Error while decoding stream #0:0: Generic error in an external library
Feb 06, 2023 15:02:24.273 [0x7f84f89a0b38] ERROR - [Req#ce5/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] Could not find ref with POC 893
Feb 06, 2023 15:02:24.274 [0x7f84f89a0b38] ERROR - [Req#ce6/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] No decoder surfaces left
Feb 06, 2023 15:02:24.274 [0x7f84f89a0b38] ERROR - [Req#ce7/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Feb 06, 2023 15:02:24.274 [0x7f84f89a0b38] ERROR - [Req#ce8/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] hardware accelerator failed to decode picture
Feb 06, 2023 15:02:24.274 [0x7f84f89a0b38] ERROR - [Req#ce9/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] Error while decoding stream #0:0: Generic error in an external library
Feb 06, 2023 15:02:24.275 [0x7f84f89a0b38] ERROR - [Req#cea/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] No decoder surfaces left
Feb 06, 2023 15:02:24.276 [0x7f84f89a0b38] ERROR - [Req#ceb/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Feb 06, 2023 15:02:24.276 [0x7f84f89a0b38] ERROR - [Req#cec/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] hardware accelerator failed to decode picture
Feb 06, 2023 15:02:24.276 [0x7f84f89a0b38] ERROR - [Req#ced/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] Error while decoding stream #0:0: Generic error in an external library
Feb 06, 2023 15:02:24.276 [0x7f84f89a0b38] ERROR - [Req#cee/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] Could not find ref with POC 897
Feb 06, 2023 15:02:24.276 [0x7f84f89a0b38] ERROR - [Req#cef/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] No decoder surfaces left
Feb 06, 2023 15:02:24.277 [0x7f84f89a0b38] ERROR - [Req#cf0/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Feb 06, 2023 15:02:24.277 [0x7f84f89a0b38] ERROR - [Req#cf1/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] hardware accelerator failed to decode picture
Feb 06, 2023 15:02:24.277 [0x7f84f89a0b38] ERROR - [Req#cf2/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] Error while decoding stream #0:0: Generic error in an external library
Feb 06, 2023 15:02:24.277 [0x7f84f89a0b38] ERROR - [Req#cf3/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] No decoder surfaces left
Feb 06, 2023 15:02:24.277 [0x7f84f89a0b38] ERROR - [Req#cf4/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Feb 06, 2023 15:02:24.277 [0x7f84f89a0b38] ERROR - [Req#cf5/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] [hevc @ 0x7fbcaa838c80] hardware accelerator failed to decode picture
Feb 06, 2023 15:02:24.278 [0x7f84f89a0b38] ERROR - [Req#cf6/Transcode/oqp2xi9bbabszonacv35fm8y/95a6c9c2-6b18-4759-b295-3ff347a6da89] Error while decoding stream #0:0: Generic error in an external library
Feb 06, 2023 15:02:27.259 [0x7f84f89a0b38] WARN - [Req#d21/Transcode] Got a transcode session ping without a valid session ID.
@pozunmv
Which PMS version please ?
@ChuckPa
Sorry about that running 1.31.0.6654-02189b09f, I can go back to the test version you posted in this thread if you want me to.
If you want. 515.76.x and 1.29.2. – That should work.
The problems being seen are as of 1.30.x when AV1 was added and Nvidia SDK updated.
IF IT DOES – Sit tight right there if you need PMS running reliably.
For me: The working & stable Nvidia formula (Nvidia 515.86.01 & PMS 1.29.2)
I could also suggest 1.25.9 but that might be too much of a database downgrade.
