Section where the issue begins:
Jan 13, 2023 20:19:30.798 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Jan 13, 2023 20:19:30.798 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Codecs: testing hevc (decoder) with hwdevice vaapi
Jan 13, 2023 20:19:30.799 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Codecs: hardware transcoding: testing API vaapi
Jan 13, 2023 20:19:30.799 [0x7fe63312db38] ERROR - [Req#16a/Transcode] [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Jan 13, 2023 20:19:30.799 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: I/O error
Jan 13, 2023 20:19:30.799 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Could not create hardware context for hevc
Jan 13, 2023 20:19:30.799 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Codecs: testing hevc (decoder) with hwdevice nvdec
Jan 13, 2023 20:19:30.799 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Codecs: hardware transcoding: testing API nvdec
Jan 13, 2023 20:19:30.799 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded lib: libcuda.so.1
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuInit
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetCount
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetAttribute
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetName
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDeviceComputeCapability
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuCtxCreate_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuCtxSetLimit
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuCtxPushCurrent_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuCtxPopCurrent_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuCtxDestroy_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMemAlloc_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMemAllocPitch_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMemsetD8Async
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMemFree_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMemcpy
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMemcpyAsync
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMemcpy2D_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMemcpy2DAsync_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuGetErrorName
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuGetErrorString
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuCtxGetDevice
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxRetain
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxRelease
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxSetFlags
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxGetState
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxReset
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuStreamCreate
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuStreamQuery
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuStreamSynchronize
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuStreamDestroy_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuStreamAddCallback
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuEventCreate
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuEventDestroy_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuEventSynchronize
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuEventQuery
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuEventRecord
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuLaunchKernel
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuLinkCreate
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuLinkAddData
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuLinkComplete
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuLinkDestroy
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuModuleLoadData
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuModuleUnload
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuModuleGetFunction
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuModuleGetGlobal
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuTexObjectCreate
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuTexObjectDestroy
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuGLGetDevices_v2
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuGraphicsGLRegisterImage
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnregisterResource
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuGraphicsMapResources
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnmapResources
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuGraphicsSubResourceGetMappedArray
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetUuid
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuImportExternalMemory
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDestroyExternalMemory
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedBuffer
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedMipmappedArray
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayGetLevel
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayDestroy
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuImportExternalSemaphore
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuDestroyExternalSemaphore
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuSignalExternalSemaphoresAsync
Jan 13, 2023 20:19:30.800 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] [FFMPEG] - Loaded sym: cuWaitExternalSemaphoresAsync
Jan 13, 2023 20:19:30.952 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Codecs: Testing with profile 'Main'
Jan 13, 2023 20:19:30.983 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] MDE: M*A*S*H - S11 E3 - Foreign Affairs: selected media 0 / 178339
Jan 13, 2023 20:19:30.983 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Streaming Resource: Adding session 0x7fe632cf5948:7cfajk52zupbf2cbh9zk4ahy which is using transcoder slot. Used slots is now 1
Jan 13, 2023 20:19:30.983 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Streaming Resource: Added session 0x7fe632cf5948:7cfajk52zupbf2cbh9zk4ahy
Jan 13, 2023 20:19:30.983 [0x7fe63312db38] DEBUG - [Req#16a/Transcode] Streaming Resource: Reached Decision id=11624 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=178339 part=(id=198634 decision=transcode container=mp4 protocol=dash streams=(Video=(id=645836 decision=transcode bitrate=2147483647 encoder=h264_nvenc width=1920 height=1080) Audio=(id=645837 decision=copy channels=2 rate=48000))))
Jan 13, 2023 20:19:30.984 [0x7fe637e8cb38] DEBUG - Completed: [10.100.102.3:65402] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F11624&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=700&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=zk8tttny0hhyjrxgmen23kn7&subtitles=burn&Accept-Language=en (22 live) TLS GZIP 859ms 1799 bytes (pipelined: 2)
Jan 13, 2023 20:19:31.303 [0x7fe6306c3b38] DEBUG - Request: [10.100.102.3:65401 (Subnet)] GET /library/sections/1/all?sort=addedAt:desc&contentDirectoryID=1&pinnedContentDirectoryID=1%2C2%2C3%2C8%2C7%2C11 (22 live) #187 TLS Page 36-95 GZIP Signed-in Token (bryanc334) (Firefox)
Jan 13, 2023 20:19:31.305 [0x7fe6306c3b38] WARN - [Req#187] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.305 [0x7fe6306c3b38] WARN - [Req#187] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.305 [0x7fe6306c3b38] DEBUG - [Req#187] Setting container serialization range to [36, 95] (total=-1)
Jan 13, 2023 20:19:31.305 [0x7fe6326b0b38] DEBUG - Request: [10.100.102.3:65384 (Subnet)] GET /hubs/home/recentlyAdded?type=2§ionID=2&contentDirectoryID=2&pinnedContentDirectoryID=1%2C2%2C3%2C8%2C7%2C11 (22 live) #184 TLS Page 36-95 GZIP Signed-in Token (bryanc334) (Firefox)
Jan 13, 2023 20:19:31.306 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'sectionID' found, ignoring.
Jan 13, 2023 20:19:31.306 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.306 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.310 [0x7fe6326b0b38] DEBUG - [Req#184] It took 0.000000 ms to retrieve 200 items.
Jan 13, 2023 20:19:31.311 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'sectionID' found, ignoring.
Jan 13, 2023 20:19:31.311 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.311 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.317 [0x7fe6326b0b38] DEBUG - [Req#184] It took 10.000000 ms to retrieve 432 items.
Jan 13, 2023 20:19:31.318 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'sectionID' found, ignoring.
Jan 13, 2023 20:19:31.318 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.318 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.324 [0x7fe6326b0b38] DEBUG - [Req#184] It took 10.000000 ms to retrieve 632 items.
Jan 13, 2023 20:19:31.324 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'sectionID' found, ignoring.
Jan 13, 2023 20:19:31.324 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.324 [0x7fe6326b0b38] WARN - [Req#184] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Jan 13, 2023 20:19:31.330 [0x7fe6306c3b38] DEBUG - [Req#187] Setting container serialization range to [36, 95] (total=1479)
Jan 13, 2023 20:19:31.332 [0x7fe6326b0b38] DEBUG - [Req#184] It took 20.000000 ms to retrieve 844 items.
Jan 13, 2023 20:19:31.340 [0x7fe637c89b38] DEBUG - Completed: [10.100.102.3:65401] 200 GET /library/sections/1/all?sort=addedAt:desc&contentDirectoryID=1&pinnedContentDirectoryID=1%2C2%2C3%2C8%2C7%2C11 (22 live) TLS GZIP Page 36-95 36ms 23987 bytes (pipelined: 3)
Jan 13, 2023 20:19:31.359 [0x7fe6326b0b38] DEBUG - [Req#184] It took 0.000000 ms to retrieve 174 items.
Jan 13, 2023 20:19:31.374 [0x7fe6326b0b38] DEBUG - Setting container serialization range to [36, 95] (total=-1)
Jan 13, 2023 20:19:31.374 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jan 13, 2023 20:19:31.374 [0x7fe6326b0b38] DEBUG - Selecting best audio stream for part ID 202846 (autoselect: 1 language: en)
Jan 13, 2023 20:19:31.374 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select a subtitle.
Jan 13, 2023 20:19:31.374 [0x7fe6326b0b38] DEBUG - Audio Stream: 680823, Subtitle Stream: -1
Jan 13, 2023 20:19:31.375 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jan 13, 2023 20:19:31.375 [0x7fe6326b0b38] DEBUG - Selecting best audio stream for part ID 202826 (autoselect: 1 language: en)
Jan 13, 2023 20:19:31.375 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select a subtitle.
Jan 13, 2023 20:19:31.375 [0x7fe6326b0b38] DEBUG - Audio Stream: 675732, Subtitle Stream: -1
Jan 13, 2023 20:19:31.376 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jan 13, 2023 20:19:31.376 [0x7fe6326b0b38] DEBUG - Selecting best audio stream for part ID 202825 (autoselect: 1 language: en)
Jan 13, 2023 20:19:31.376 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select a subtitle.
Jan 13, 2023 20:19:31.376 [0x7fe6326b0b38] DEBUG - Audio Stream: 675729, Subtitle Stream: -1
Jan 13, 2023 20:19:31.378 [0x7fe6326b0b38] DEBUG - There were 1 top-level paths for Slow Horses.
Jan 13, 2023 20:19:31.382 [0x7fe6326b0b38] DEBUG - There were 1 top-level paths for Married to Medicine.
Jan 13, 2023 20:19:31.389 [0x7fe6326b0b38] DEBUG - There were 1 top-level paths for The Joy of Painting.
Jan 13, 2023 20:19:31.392 [0x7fe6326b0b38] DEBUG - There were 1 top-level paths for American Horror Story.
Jan 13, 2023 20:19:31.392 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jan 13, 2023 20:19:31.393 [0x7fe6326b0b38] DEBUG - Selecting best audio stream for part ID 202037 (autoselect: 1 language: en)
Jan 13, 2023 20:19:31.393 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select a subtitle.
Jan 13, 2023 20:19:31.393 [0x7fe6326b0b38] DEBUG - Subtitles: Found a candidate subtitle language [en] for a foreign film
Jan 13, 2023 20:19:31.393 [0x7fe6326b0b38] DEBUG - Audio Stream: 673364, Subtitle Stream: 673365
Jan 13, 2023 20:19:31.393 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jan 13, 2023 20:19:31.393 [0x7fe6326b0b38] DEBUG - Selecting best audio stream for part ID 202048 (autoselect: 1 language: en)
Jan 13, 2023 20:19:31.393 [0x7fe6326b0b38] DEBUG - Audio Stream: 673376, Subtitle Stream: -1
Jan 13, 2023 20:19:31.394 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jan 13, 2023 20:19:31.394 [0x7fe6326b0b38] DEBUG - Selecting best audio stream for part ID 201701 (autoselect: 1 language: en)
Jan 13, 2023 20:19:31.394 [0x7fe6326b0b38] DEBUG - We're going to try to auto-select a subtitle.
Jan 13, 2023 20:19:31.394 [0x7fe6326b0b38] DEBUG - Audio Stream: 672296, Subtitle Stream: -1
Jan 13, 2023 20:19:31.397 [0x7fe6326b0b38] DEBUG - There were 1 top-level paths for Raising Hope.
Jan 13, 2023 20:19:31.398 [0x7fe6326b0b38] DEBUG - There were 1 top-level paths for Harley Quinn.
Jan 13, 2023 20:19:31.401 [0x7fe637c89b38] DEBUG - Completed: [10.100.102.3:65384] 200 GET /hubs/home/recentlyAdded?type=2§ionID=2&contentDirectoryID=2&pinnedContentDirectoryID=1%2C2%2C3%2C8%2C7%2C11 (22 live) TLS GZIP Page 36-95 96ms 14910 bytes (pipelined: 15)
Jan 13, 2023 20:19:31.599 [0x7fe627fffb38] DEBUG - Request: [10.100.102.3:65401 (Subnet)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F11624&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=700&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=zk8tttny0hhyjrxgmen23kn7&subtitles=burn&Accept-Language=en (22 live) #18a TLS GZIP Signed-in Token (bryanc334) (Firefox)
Jan 13, 2023 20:19:31.599 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] Found session GUID of zk8tttny0hhyjrxgmen23kn7 in session start.
Jan 13, 2023 20:19:31.599 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: append-transcode-target-codec(type=videoProfile&context=streaming&audioCodec=aac&protocol=dash)
Jan 13, 2023 20:19:31.600 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] TranscodeUniversalRequest: using augmented profile Firefox
Jan 13, 2023 20:19:31.600 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/11624?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=7cfajk52zupbf2cbh9zk4ahy
Jan 13, 2023 20:19:31.611 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode/Req#18c] We're going to try to auto-select an audio stream for account 1.
Jan 13, 2023 20:19:31.611 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode/Req#18c] Selecting best audio stream for part ID 198634 (autoselect: 1 language: en)
Jan 13, 2023 20:19:31.611 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode/Req#18c] We're going to try to auto-select a subtitle.
Jan 13, 2023 20:19:31.611 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode/Req#18c] Audio Stream: 645837, Subtitle Stream: -1
Jan 13, 2023 20:19:31.613 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] Found session GUID of zk8tttny0hhyjrxgmen23kn7 in session start.
Jan 13, 2023 20:19:31.613 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] Cleaning directory for session zk8tttny0hhyjrxgmen23kn7 ()
Jan 13, 2023 20:19:31.613 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] Starting a transcode session zk8tttny0hhyjrxgmen23kn7 at offset -1.0 (state=3)
Jan 13, 2023 20:19:31.614 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] TPU: hardware transcoding: using hardware decode accelerator nvdec
Jan 13, 2023 20:19:31.614 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] TPU: hardware transcoding: zero-copy support present
Jan 13, 2023 20:19:31.614 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] TPU: hardware transcoding: using zero-copy transcoding
Jan 13, 2023 20:19:31.614 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] [Universal] Using local file path instead of URL: /mnt/storage3/storage3-TV/M-A-S-H/Season 11/MASH.S11E03.Foreign.Affairs.WEBRip.1080p.AAC.H265-d3g.mkv
Jan 13, 2023 20:19:31.614 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] TPU: hardware transcoding: final decoder: nvdec, final encoder: nvenc
Jan 13, 2023 20:19:31.615 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode/JobRunner] Job running: CUDA_CACHE_PATH="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Shaders/CUDA" FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/acf6c67-4446-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxx4cf9-b353-8a80a1f4fe53 "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 hevc -hwaccel:0 nvdec -hwaccel_fallback_threshold:0 10 -threads:0 1 -hwaccel_output_format:0 cuda -hwaccel_device:0 cuda -analyzeduration 20000000 -probesize 20000000 -i "/mnt/storage3/storage3-TV/M-A-S-H/Season 11/MASH.S11E03.Foreign.Affairs.WEBRip.1080p.AAC.H265-d3g.mkv" -filter_complex "[0:0]hwupload[0];[0]scale_cuda=w=1920:h=1080:format=nv12[1]" -map "[1]" -codec:0 h264_nvenc -b:0 20000k -preset:0 hq -forced-idr:0 1 -r:0 23.975999999999999 -force_key_frames:0 "expr:gte(t,n_forced*1)" -map 0:1 -metadata:s:1 language=eng -codec:1 copy -copypriorss:1 0 -f dash -seg_duration 1 -dash_segment_type mp4 -init_seg_name 'init-stream$RepresentationID$.m4s' -media_seg_name 'chunk-stream$RepresentationID$-$Number%05d$.m4s' -window_size 5 -delete_removed false -skip_to_segment 1 -time_delta 0.0625 -manifest_name "http://127.0.0.1:32400/video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/manifest?X-Plex-Http-Pipeline=infinite" -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -start_at_zero -copyts -vsync cfr -init_hw_device cuda=cuda: -filter_hw_device cuda -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress
Jan 13, 2023 20:19:31.615 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode/JobRunner] In directory: "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-zk8tttny0hhyjrxgmen23kn7-e7a03df6-6c6e-43c0-906d-1fbb3aed7907"
Jan 13, 2023 20:19:31.615 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode/JobRunner] Jobs: Starting child process with pid 7798
Jan 13, 2023 20:19:31.648 [0x7fe63312db38] DEBUG - Request: [127.0.0.1:43056 (Loopback)] PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?status=startup (23 live) #17d Signed-in Token (bryanc334) (range: bytes=0-)
Jan 13, 2023 20:19:31.648 [0x7fe637e8cb38] DEBUG - Completed: [127.0.0.1:43056] 204 PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?status=startup (23 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Jan 13, 2023 20:19:31.803 [0x7fe6306c3b38] DEBUG - Request: [127.0.0.1:43056 (Loopback)] PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?status=startup (23 live) #18f Signed-in Token (bryanc334) (range: bytes=0-)
Jan 13, 2023 20:19:31.803 [0x7fe637e8cb38] DEBUG - Completed: [127.0.0.1:43056] 204 PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?status=startup (23 live) 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Jan 13, 2023 20:19:31.803 [0x7fe6326b0b38] DEBUG - Request: [127.0.0.1:43056 (Loopback)] PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?status=opening (23 live) #190 Signed-in Token (bryanc334) (range: bytes=0-)
Jan 13, 2023 20:19:31.803 [0x7fe637c89b38] DEBUG - Completed: [127.0.0.1:43056] 204 PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?status=opening (23 live) 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Jan 13, 2023 20:19:31.805 [0x7fe6304c0b38] DEBUG - Request: [127.0.0.1:43056 (Loopback)] PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?status=opened (23 live) #191 Signed-in Token (bryanc334) (range: bytes=0-)
Jan 13, 2023 20:19:31.805 [0x7fe637e8cb38] DEBUG - Completed: [127.0.0.1:43056] 204 PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?status=opened (23 live) 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Jan 13, 2023 20:19:31.805 [0x7fe63312db38] DEBUG - Request: [127.0.0.1:43056 (Loopback)] PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress/stream?index=0&id=0&codec=hevc&type=video (23 live) #192 Signed-in Token (bryanc334) (range: bytes=0-)
Jan 13, 2023 20:19:31.805 [0x7fe637e8cb38] DEBUG - Completed: [127.0.0.1:43056] 200 PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress/stream?index=0&id=0&codec=hevc&type=video (23 live) 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Jan 13, 2023 20:19:31.808 [0x7fe6306c3b38] DEBUG - Request: [127.0.0.1:43056 (Loopback)] PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress/stream?index=1&id=0&codec=aac&type=audio&profile=HE-AAC (23 live) #193 Signed-in Token (bryanc334) (range: bytes=0-)
Jan 13, 2023 20:19:31.809 [0x7fe637c89b38] DEBUG - Completed: [127.0.0.1:43056] 200 PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress/stream?index=1&id=0&codec=aac&type=audio&profile=HE-AAC (23 live) 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Jan 13, 2023 20:19:31.809 [0x7fe6326b0b38] DEBUG - Request: [127.0.0.1:43056 (Loopback)] PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress/streamDetail?index=0&id=0&codec=hevc&type=video&profile=Main&width=1920&height=1080&interlaced=0&sar=1:1&level=120&frameRate=23.976&disp_default=1 (23 live) #194 Signed-in Token (bryanc334) (range: bytes=0-)
Jan 13, 2023 20:19:31.809 [0x7fe637e8cb38] DEBUG - Completed: [127.0.0.1:43056] 200 PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress/streamDetail?index=0&id=0&codec=hevc&type=video&profile=Main&width=1920&height=1080&interlaced=0&sar=1:1&level=120&frameRate=23.976&disp_default=1 (23 live) 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Jan 13, 2023 20:19:31.809 [0x7fe6304c0b38] DEBUG - Request: [127.0.0.1:43056 (Loopback)] PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress/streamDetail?index=1&id=0&codec=aac&type=audio&profile=HE-AAC&language=eng&channels=2&layout=stereo&sampleRate=48000&disp_default=1 (23 live) #195 Signed-in Token (bryanc334) (range: bytes=0-)
Jan 13, 2023 20:19:31.810 [0x7fe637c89b38] DEBUG - Completed: [127.0.0.1:43056] 200 PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress/streamDetail?index=1&id=0&codec=aac&type=audio&profile=HE-AAC&language=eng&channels=2&layout=stereo&sampleRate=48000&disp_default=1 (23 live) 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Jan 13, 2023 20:19:31.811 [0x7fe63312db38] DEBUG - Request: [127.0.0.1:43056 (Loopback)] PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?duration=1498.070000 (23 live) #196 Signed-in Token (bryanc334) (range: bytes=0-)
Jan 13, 2023 20:19:31.811 [0x7fe627fffb38] DEBUG - [Req#18a/Transcode] Started session successfully: zk8tttny0hhyjrxgmen23kn7
Jan 13, 2023 20:19:31.811 [0x7fe637e8cb38] DEBUG - Completed: [127.0.0.1:43056] 204 PUT /video/:/transcode/session/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907/progress?duration=1498.070000 (23 live) 0ms 203 bytes (pipelined: 9) (range: bytes=0-)
Jan 13, 2023 20:19:31.812 [0x7fe637e8cb38] DEBUG - Completed: [10.100.102.3:65401] 200 GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F11624&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=700&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=zk8tttny0hhyjrxgmen23kn7&subtitles=burn&Accept-Language=en (23 live) TLS GZIP 212ms 1079 bytes (pipelined: 4)
Jan 13, 2023 20:19:31.821 [0x7fe6306c3b38] DEBUG - Request: [10.100.102.3:65401 (Subnet)] GET /status/sessions (23 live) #1a0 TLS GZIP Signed-in Token (bryanc334) (Firefox)
Jan 13, 2023 20:19:31.821 [0x7fe6306c3b38] DEBUG - [Req#1a0] [Now] Adding 3 sessions.
Jan 13, 2023 20:19:31.822 [0x7fe637c89b38] DEBUG - Completed: [10.100.102.3:65401] 200 GET /status/sessions (23 live) TLS GZIP 0ms 2017 bytes (pipelined: 5)
Jan 13, 2023 20:19:31.823 [0x7fe6326b0b38] DEBUG - Request: [127.0.0.1:53348 (Loopback)] GET /status/sessions (23 live) #17b TLS GZIP Signed-in Token (bryanc334) (Firefox)
Jan 13, 2023 20:19:31.823 [0x7fe6326b0b38] DEBUG - [Req#17b] [Now] Adding 3 sessions.
Jan 13, 2023 20:19:31.824 [0x7fe637e8cb38] DEBUG - Completed: [127.0.0.1:53348] 200 GET /status/sessions (23 live) TLS GZIP 0ms 1892 bytes (pipelined: 10)
Jan 13, 2023 20:19:31.837 [0x7fe6304c0b38] DEBUG - Request: [10.100.102.3:65401 (Subnet)] GET /video/:/transcode/universal/session/zk8tttny0hhyjrxgmen23kn7/1/header (23 live) #1a1 TLS GZIP Signed-in
Jan 13, 2023 20:19:31.839 [0x7fe63312db38] DEBUG - Request: [10.100.102.3:65384 (Subnet)] GET /video/:/transcode/universal/session/zk8tttny0hhyjrxgmen23kn7/0/header (23 live) #18b TLS GZIP Signed-in
Jan 13, 2023 20:19:31.968 [0x7fe6306c3b38] ERROR - [Req#1a3/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
Jan 13, 2023 20:19:31.969 [0x7fe6326b0b38] ERROR - [Req#1a4/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 13, 2023 20:19:31.969 [0x7fe627fffb38] ERROR - [Req#1a5/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] hardware accelerator failed to decode picture
Jan 13, 2023 20:19:31.970 [0x7fe6306c3b38] ERROR - [Req#1a6/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] Error while decoding stream #0:0: Generic error in an external library
Jan 13, 2023 20:19:31.971 [0x7fe6326b0b38] ERROR - [Req#1a7/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] Could not find ref with POC 8
Jan 13, 2023 20:19:31.971 [0x7fe627fffb38] ERROR - [Req#1a8/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
Jan 13, 2023 20:19:31.972 [0x7fe6306c3b38] ERROR - [Req#1a9/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 13, 2023 20:19:31.972 [0x7fe6326b0b38] ERROR - [Req#1aa/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] hardware accelerator failed to decode picture
Jan 13, 2023 20:19:31.973 [0x7fe627fffb38] ERROR - [Req#1ab/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] Error while decoding stream #0:0: Generic error in an external library
Jan 13, 2023 20:19:31.974 [0x7fe6306c3b38] ERROR - [Req#1ac/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] Could not find ref with POC 9
Jan 13, 2023 20:19:31.974 [0x7fe6326b0b38] ERROR - [Req#1ad/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
Jan 13, 2023 20:19:31.975 [0x7fe627fffb38] ERROR - [Req#1ae/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 13, 2023 20:19:31.975 [0x7fe6306c3b38] ERROR - [Req#1af/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] hardware accelerator failed to decode picture
Jan 13, 2023 20:19:31.976 [0x7fe6326b0b38] ERROR - [Req#1b0/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] Error while decoding stream #0:0: Generic error in an external library
Jan 13, 2023 20:19:31.977 [0x7fe627fffb38] ERROR - [Req#1b1/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] Could not find ref with POC 10
Jan 13, 2023 20:19:31.977 [0x7fe6306c3b38] ERROR - [Req#1b2/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
Jan 13, 2023 20:19:31.978 [0x7fe6326b0b38] ERROR - [Req#1b3/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 13, 2023 20:19:31.979 [0x7fe627fffb38] ERROR - [Req#1b4/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] hardware accelerator failed to decode picture
Jan 13, 2023 20:19:31.979 [0x7fe6306c3b38] ERROR - [Req#1b5/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] Error while decoding stream #0:0: Generic error in an external library
Jan 13, 2023 20:19:31.980 [0x7fe6326b0b38] ERROR - [Req#1b6/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] Could not find ref with POC 11
Jan 13, 2023 20:19:31.981 [0x7fe627fffb38] ERROR - [Req#1b7/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
Jan 13, 2023 20:19:31.981 [0x7fe6306c3b38] ERROR - [Req#1b8/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 13, 2023 20:19:31.982 [0x7fe6326b0b38] ERROR - [Req#1b9/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] hardware accelerator failed to decode picture
Jan 13, 2023 20:19:31.983 [0x7fe627fffb38] ERROR - [Req#1ba/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] Error while decoding stream #0:0: Generic error in an external library
Jan 13, 2023 20:19:31.983 [0x7fe6306c3b38] ERROR - [Req#1bb/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] Could not find ref with POC 12
Jan 13, 2023 20:19:31.984 [0x7fe6326b0b38] ERROR - [Req#1bc/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
Jan 13, 2023 20:19:31.985 [0x7fe627fffb38] ERROR - [Req#1bd/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 13, 2023 20:19:31.985 [0x7fe6306c3b38] ERROR - [Req#1be/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] hardware accelerator failed to decode picture
Jan 13, 2023 20:19:31.986 [0x7fe6326b0b38] ERROR - [Req#1bf/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] Error while decoding stream #0:0: Generic error in an external library
Jan 13, 2023 20:19:31.987 [0x7fe627fffb38] ERROR - [Req#1c0/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] Could not find ref with POC 13
Jan 13, 2023 20:19:31.988 [0x7fe6306c3b38] ERROR - [Req#1c1/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
Jan 13, 2023 20:19:31.989 [0x7fe6326b0b38] ERROR - [Req#1c2/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 13, 2023 20:19:31.989 [0x7fe627fffb38] ERROR - [Req#1c3/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] hardware accelerator failed to decode picture
Jan 13, 2023 20:19:31.990 [0x7fe6306c3b38] ERROR - [Req#1c4/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] Error while decoding stream #0:0: Generic error in an external library
Jan 13, 2023 20:19:31.991 [0x7fe6326b0b38] ERROR - [Req#1c5/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] Could not find ref with POC 14
Jan 13, 2023 20:19:31.991 [0x7fe627fffb38] ERROR - [Req#1c6/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
Jan 13, 2023 20:19:31.992 [0x7fe6306c3b38] ERROR - [Req#1c7/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 13, 2023 20:19:31.993 [0x7fe6326b0b38] ERROR - [Req#1c8/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] hardware accelerator failed to decode picture
Jan 13, 2023 20:19:31.994 [0x7fe627fffb38] ERROR - [Req#1c9/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] Error while decoding stream #0:0: Generic error in an external library
Jan 13, 2023 20:19:31.995 [0x7fe6306c3b38] ERROR - [Req#1ca/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] Could not find ref with POC 15
Jan 13, 2023 20:19:31.995 [0x7fe6326b0b38] ERROR - [Req#1cb/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
Jan 13, 2023 20:19:31.996 [0x7fe627fffb38] ERROR - [Req#1cc/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] decoder->cvdl->cuvidDecodePicture(decoder->decoder, &ctx->pic_params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
Jan 13, 2023 20:19:31.997 [0x7fe6306c3b38] ERROR - [Req#1cd/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] hardware accelerator failed to decode picture
Jan 13, 2023 20:19:31.998 [0x7fe6326b0b38] ERROR - [Req#1ce/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] Error while decoding stream #0:0: Generic error in an external library
Jan 13, 2023 20:19:31.999 [0x7fe627fffb38] ERROR - [Req#1cf/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] Could not find ref with POC 16
Jan 13, 2023 20:19:31.999 [0x7fe6306c3b38] ERROR - [Req#1d0/Transcode/zk8tttny0hhyjrxgmen23kn7/e7a03df6-6c6e-43c0-906d-1fbb3aed7907] [hevc @ 0x7f092ad66c80] No decoder surfaces left
