Hardware Transcoding Not Working
I am sharing because I made an error.
This server is headless therefore it gets the nvidia-driver-550-server package.
Below is the entire sequence of uninstall (with purge) and install of proper ‘server’ (headless) driver.
Now I’ll reboot
root@glockner:/home/chuck# sudo apt remove --purge $(dpkg -l | grep nvidia | awk '{print $2}')
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages were automatically installed and are no longer required:
  ca-certificates-java dctrl-tools dkms fonts-dejavu-extra java-common libaccinj64-11.5 libatk-wrapper-java
  libatk-wrapper-java-jni libbabeltrace1 libboost-regex1.74.0 libcub-dev libcublas11 libcublaslt11 libcudart11.0 libcufftw10
  libcuinj64-11.5 libcupti-dev libcupti-doc libcupti11.5 libcurand10 libcusolver11 libcusolvermg11 libcusparse11
  libdebuginfod-common libdebuginfod1 libdouble-conversion3 libegl-dev libgail-common libgail18 libgl-dev libgl1-mesa-dev
  libgles-dev libgles1 libglvnd-core-dev libglvnd-dev libglx-dev libgtk2.0-0 libgtk2.0-bin libgtk2.0-common libipt2 libnppc11
  libnppial11 libnppicc11 libnppidei11 libnppif11 libnppig11 libnppim11 libnppist11 libnppisu11 libnppitc11 libnpps11
  libnvblas11 libnvidia-compute-495 libnvidia-compute-510 libnvjpeg11 libnvrtc-builtins11.5 libnvrtc11.2 libnvtoolsext1
  libnvvm4 libopengl-dev libopengl0 libpcre2-16-0 libpthread-stubs0-dev libqt5core5a libqt5dbus5 libqt5network5
  libsource-highlight-common libsource-highlight4v5 libtbb-dev libtbb12 libtbbmalloc2 libthrust-dev libvdpau-dev libx11-dev
  libxau-dev libxcb-icccm4 libxcb-image0 libxcb-keysyms1 libxcb-render-util0 libxcb-util1 libxcb-xinerama0 libxcb-xkb1
  libxcb1-dev libxcvt0 libxdmcp-dev libxfont2 libxkbcommon-x11-0 libxnvctrl0 node-html5shiv nsight-compute
  nsight-compute-target nsight-systems nsight-systems-target ocl-icd-opencl-dev opencl-c-headers opencl-clhpp-headers
  openjdk-8-jre openjdk-8-jre-headless pkg-config python3-blessings qttranslations5-l10n x11-xkb-utils x11proto-core-dev
  x11proto-dev xcvt xfonts-base xfonts-encodings xfonts-utils xorg-sgml-doctools xserver-common xserver-xorg-core xtrans-dev
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  libnvidia-compute-495 libnvidia-compute-510 libnvidia-compute-535
The following packages will be REMOVED:
  gpustat* libnvidia-cfg1-550* libnvidia-common-550* libnvidia-compute-535-server* libnvidia-compute-550*
  libnvidia-decode-550* libnvidia-egl-wayland1* libnvidia-encode-550* libnvidia-extra-550* libnvidia-fbc1-550*
  libnvidia-gl-550* libnvidia-ml-dev* nvidia-compute-utils-535-server* nvidia-compute-utils-550* nvidia-cuda-dev*
  nvidia-cuda-gdb* nvidia-cuda-toolkit* nvidia-cuda-toolkit-doc* nvidia-dkms-535-server* nvidia-dkms-550* nvidia-driver-550*
  nvidia-firmware-535-server-535.183.06* nvidia-firmware-550-550.107.02* nvidia-kernel-common-535-server*
  nvidia-kernel-common-550* nvidia-kernel-source-550* nvidia-opencl-dev* nvidia-prime* nvidia-profiler* nvidia-settings*
  nvidia-utils-550* nvidia-visual-profiler* screen-resolution-extra* xserver-xorg-video-nvidia-550*
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 34 to remove and 0 not upgraded.
Need to get 40.7 MB of archives.
After this operation, 2,817 MB disk space will be freed.
Do you want to continue? [Y/n] y
Get:1 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-compute-495 amd64 510.108.03-0ubuntu0.22.04.1 [7,378 B]
Get:2 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-compute-535 amd64 535.183.01-0ubuntu0.22.04.1 [40.7 MB]
Get:3 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-compute-510 amd64 525.147.05-0ubuntu2.22.04.1 [7,310 B]
Fetched 40.7 MB in 2s (22.9 MB/s)
(Reading database ... 223126 files and directories currently installed.)
Removing gpustat (0.6.0-1) ...
Removing nvidia-driver-550 (550.107.02-0ubuntu0.22.04.1) ...
Removing xserver-xorg-video-nvidia-550 (550.107.02-0ubuntu0.22.04.1) ...
Removing libnvidia-cfg1-550:amd64 (550.107.02-0ubuntu0.22.04.1) ...
Removing libnvidia-gl-550:amd64 (550.107.02-0ubuntu0.22.04.1) ...
Removing libnvidia-common-550 (550.107.02-0ubuntu0.22.04.1) ...
Removing nvidia-utils-550 (550.107.02-0ubuntu0.22.04.1) ...
Removing nvidia-cuda-toolkit (11.5.1-1ubuntu1) ...
Removing nvidia-cuda-dev:amd64 (11.5.1-1ubuntu1) ...
Removing libnvidia-ml-dev:amd64 (11.5.50~11.5.1-1ubuntu1) ...
Removing libnvidia-encode-550:amd64 (550.107.02-0ubuntu0.22.04.1) ...
Removing libnvidia-decode-550:amd64 (550.107.02-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-compute-495:amd64.
(Reading database ... 222358 files and directories currently installed.)
Preparing to unpack .../libnvidia-compute-495_510.108.03-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-compute-495:amd64 (510.108.03-0ubuntu0.22.04.1) ...
dpkg: libnvidia-compute-550:amd64: dependency problems, but removing anyway as you requested:
 nvidia-compute-utils-550 depends on libnvidia-compute-550.
 nsight-systems-target:amd64 depends on libnvidia-compute-495 (>= 495) | libnvidia-compute-495-server (>= 495) | libcuda.so.1 (>
= 495) | libcuda-11.5-1; however:
  Package libnvidia-compute-495:amd64 is not configured yet.
  Package libnvidia-compute-495-server is not installed.
  Package libcuda.so.1 is not installed.
  Package libnvidia-compute-550:amd64 which provides libcuda.so.1 is to be removed.
  Package libnvidia-compute-535-server:amd64 which provides libcuda.so.1 is not installed.
  Package libcuda-11.5-1 is not installed.
  Package libnvidia-compute-550:amd64 which provides libcuda-11.5-1 is to be removed.
  Package libnvidia-compute-535-server:amd64 which provides libcuda-11.5-1 is not installed.
 libcuinj64-11.5:amd64 depends on libnvidia-compute-495 (>= 495) | libnvidia-compute-495-server (>= 495) | libcuda.so.1 (>= 495)
 python3-pynvml depends on libnvidia-ml.so.1 | libnvidia-ml1; however:
  Package libnvidia-ml.so.1 is not installed.
  Package libnvidia-compute-550:amd64 which provides libnvidia-ml.so.1 is to be removed.
  Package libnvidia-compute-535-server:amd64 which provides libnvidia-ml.so.1 is not installed.
  Package libnvidia-ml1 is not installed.
(Reading database ... 222359 files and directories currently installed.)
Removing libnvidia-compute-550:amd64 (550.107.02-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-compute-535:amd64.
(Reading database ... 222340 files and directories currently installed.)
Preparing to unpack .../libnvidia-compute-535_535.183.01-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-compute-535:amd64 (535.183.01-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-compute-510:amd64.
Preparing to unpack .../libnvidia-compute-510_525.147.05-0ubuntu2.22.04.1_amd64.deb ...
Unpacking libnvidia-compute-510:amd64 (525.147.05-0ubuntu2.22.04.1) ...
(Reading database ... 222362 files and directories currently installed.)
Removing libnvidia-egl-wayland1:amd64 (1:1.1.9-1.1) ...
Removing libnvidia-extra-550:amd64 (550.107.02-0ubuntu0.22.04.1) ...
Removing libnvidia-fbc1-550:amd64 (550.107.02-0ubuntu0.22.04.1) ...
Removing nvidia-compute-utils-550 (550.107.02-0ubuntu0.22.04.1) ...
Removing nvidia-cuda-gdb (11.5.114~11.5.1-1ubuntu1) ...
Removing nvidia-cuda-toolkit-doc (11.5.1-1ubuntu1) ...
Removing nvidia-dkms-550 (550.107.02-0ubuntu0.22.04.1) ...
Removing all DKMS Modules
Done.
INFO:Disable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
update-initramfs: deferring update (trigger activated)
Removing nvidia-firmware-535-server-535.183.06 (535.183.06-0ubuntu0.22.04.1) ...
Removing nvidia-kernel-common-550 (550.107.02-0ubuntu0.22.04.1) ...
Removing nvidia-firmware-550-550.107.02 (550.107.02-0ubuntu0.22.04.1) ...
Removing nvidia-kernel-source-550 (550.107.02-0ubuntu0.22.04.1) ...
Removing nvidia-opencl-dev:amd64 (11.5.1-1ubuntu1) ...
Removing nvidia-prime (0.8.17.1) ...
Removing nvidia-visual-profiler (11.5.114~11.5.1-1ubuntu1) ...
Removing nvidia-profiler (11.5.114~11.5.1-1ubuntu1) ...
Removing nvidia-settings (510.47.03-0ubuntu1) ...
Removing screen-resolution-extra (0.18.2) ...
Setting up libnvidia-compute-535:amd64 (535.183.01-0ubuntu0.22.04.1) ...
Setting up libnvidia-compute-510:amd64 (525.147.05-0ubuntu2.22.04.1) ...
Setting up libnvidia-compute-495:amd64 (510.108.03-0ubuntu0.22.04.1) ...
Processing triggers for initramfs-tools (0.140ubuntu13.4) ...
update-initramfs: Generating /boot/initrd.img-6.8.0-40-generic
W: Possible missing firmware /lib/firmware/ast_dp501_fw.bin for module ast
Processing triggers for libc-bin (2.35-0ubuntu3.8) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
(Reading database ... 219996 files and directories currently installed.)
Purging configuration files for nvidia-dkms-535-server (535.183.06-0ubuntu0.22.04.1) ...
Purging configuration files for libnvidia-compute-550:amd64 (550.107.02-0ubuntu0.22.04.1) ...
Purging configuration files for nvidia-prime (0.8.17.1) ...
Purging configuration files for nvidia-dkms-550 (550.107.02-0ubuntu0.22.04.1) ...
Purging configuration files for nvidia-compute-utils-550 (550.107.02-0ubuntu0.22.04.1) ...
Purging configuration files for nvidia-cuda-toolkit (11.5.1-1ubuntu1) ...
Purging configuration files for libnvidia-compute-535-server:amd64 (535.183.06-0ubuntu0.22.04.1) ...
Purging configuration files for nvidia-kernel-common-550 (550.107.02-0ubuntu0.22.04.1) ...
Purging configuration files for nvidia-kernel-common-535-server (535.183.06-0ubuntu0.22.04.1) ...
Purging configuration files for nvidia-settings (510.47.03-0ubuntu1) ...
Purging configuration files for nvidia-compute-utils-535-server (535.183.06-0ubuntu0.22.04.1) ...
Scanning processes...
Scanning candidates...
Scanning processor microcode...
Scanning linux images...
Running kernel seems to be up-to-date.
The processor microcode seems to be up-to-date.
Restarting services...
 systemctl restart plexmediaserver.service
No containers need to be restarted.
No user sessions are running outdated binaries.
No VM guests are running outdated hypervisor (qemu) binaries on this host.
root@glockner:/home/chuck# dpkg -l | grep nvidia
ii  libnvidia-compute-495:amd64            510.108.03-0ubuntu0.22.04.1              amd64        Transitional package for libnvidia-compute-510
ii  libnvidia-compute-510:amd64            525.147.05-0ubuntu2.22.04.1              amd64        Transitional package for libnvidia-compute-535
ii  libnvidia-compute-535:amd64            535.183.01-0ubuntu0.22.04.1              amd64        NVIDIA libcompute package
root@glockner:/home/chuck# sudo apt install nvidia-driver-550-server
  ca-certificates-java fonts-dejavu-extra java-common libaccinj64-11.5 libatk-wrapper-java libatk-wrapper-java-jni
  libbabeltrace1 libboost-regex1.74.0 libcub-dev libcublas11 libcublaslt11 libcudart11.0 libcufftw10 libcuinj64-11.5
  libcupti-dev libcupti-doc libcupti11.5 libcurand10 libcusolver11 libcusolvermg11 libcusparse11 libdebuginfod-common
  libdebuginfod1 libdouble-conversion3 libegl-dev libgail-common libgail18 libgl-dev libgl1-mesa-dev libgles-dev libgles1
  libglvnd-core-dev libglvnd-dev libglx-dev libgtk2.0-0 libgtk2.0-bin libgtk2.0-common libipt2 libnppc11 libnppial11
  libnppicc11 libnppidei11 libnppif11 libnppig11 libnppim11 libnppist11 libnppisu11 libnppitc11 libnpps11 libnvblas11
  libnvjpeg11 libnvrtc-builtins11.5 libnvrtc11.2 libnvtoolsext1 libnvvm4 libopengl-dev libopengl0 libpcre2-16-0
  libpthread-stubs0-dev libqt5core5a libqt5dbus5 libqt5network5 libsource-highlight-common libsource-highlight4v5 libtbb-dev
  libtbb12 libtbbmalloc2 libthrust-dev libvdpau-dev libx11-dev libxau-dev libxcb-icccm4 libxcb-image0 libxcb-keysyms1
  libxcb-render-util0 libxcb-util1 libxcb-xinerama0 libxcb-xkb1 libxcb1-dev libxdmcp-dev libxkbcommon-x11-0 libxnvctrl0
  node-html5shiv nsight-compute nsight-compute-target nsight-systems nsight-systems-target ocl-icd-opencl-dev opencl-c-headers
  opencl-clhpp-headers openjdk-8-jre openjdk-8-jre-headless pkg-config python3-blessings qttranslations5-l10n
  x11proto-core-dev x11proto-dev xorg-sgml-doctools xtrans-dev
  libnvidia-cfg1-550-server libnvidia-common-550-server libnvidia-compute-550-server libnvidia-decode-550-server
  libnvidia-encode-550-server libnvidia-extra-550-server libnvidia-fbc1-550-server libnvidia-gl-550-server
  nvidia-compute-utils-550-server nvidia-dkms-550-server nvidia-firmware-550-server-550.90.07 nvidia-kernel-common-550-server
  nvidia-kernel-source-550-server nvidia-utils-550-server xserver-xorg-video-nvidia-550-server
Suggested packages:
  nvidia-settings nvidia-prime
Recommended packages:
  libnvidia-compute-550-server:i386 libnvidia-decode-550-server:i386 libnvidia-encode-550-server:i386
  libnvidia-fbc1-550-server:i386 libnvidia-gl-550-server:i386
  nvidia-compute-utils-550-server nvidia-dkms-550-server nvidia-driver-550-server nvidia-firmware-550-server-550.90.07
  nvidia-kernel-common-550-server nvidia-kernel-source-550-server nvidia-utils-550-server xserver-xorg-video-nvidia-550-server
0 upgraded, 16 newly installed, 3 to remove and 0 not upgraded.
Need to get 283 MB of archives.
After this operation, 543 MB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-compute-550-server amd64 550.90.07-0ubuntu0.22.04.1 [41.8 MB]
Get:2 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-cfg1-550-server amd64 550.90.07-0ubuntu0.22.04.1 [158 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-common-550-server all 550.90.07-0ubuntu0.22.04.1 [14.9 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-decode-550-server amd64 550.90.07-0ubuntu0.22.04.1 [2,046 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-encode-550-server amd64 550.90.07-0ubuntu0.22.04.1 [106 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-extra-550-server amd64 550.90.07-0ubuntu0.22.04.1 [74.3 kB]
Get:7 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-fbc1-550-server amd64 550.90.07-0ubuntu0.22.04.1 [56.8 kB]
Get:8 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-gl-550-server amd64 550.90.07-0ubuntu0.22.04.1 [156 MB]
Get:9 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-compute-utils-550-server amd64 550.90.07-0ubuntu0.22.04.1 [124 kB]
Get:10 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-kernel-source-550-server amd64 550.90.07-0ubuntu0.22.04.1 [42.1 MB]
Get:11 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-firmware-550-server-550.90.07 amd64 550.90.07-0ubuntu0.22.04.1 [38.3 MB]
Get:12 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-kernel-common-550-server amd64 550.90.07-0ubuntu0.22.04.1 [127 kB]
Get:13 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-dkms-550-server amd64 550.90.07-0ubuntu0.22.04.1 [50.2 kB]
Get:14 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-utils-550-server amd64 550.90.07-0ubuntu0.22.04.1 [532 kB]
Get:15 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 xserver-xorg-video-nvidia-550-server amd64 550.90.07-0ubuntu0.22.04.1 [1,630 kB]
Get:16 http://us.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-driver-550-server amd64 550.90.07-0ubuntu0.22.04.1 [488 kB]
Fetched 283 MB in 5s (62.7 MB/s)
dpkg: libnvidia-compute-535:amd64: dependency problems, but removing anyway as you requested:
 libnvidia-compute-510:amd64 depends on libnvidia-compute-535.
  Package libnvidia-compute-535:amd64 which provides libnvidia-ml.so.1 is to be removed.
(Reading database ... 219993 files and directories currently installed.)
Removing libnvidia-compute-535:amd64 (535.183.01-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-compute-550-server:amd64.
(Reading database ... 219974 files and directories currently installed.)
Preparing to unpack .../libnvidia-compute-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-compute-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
dpkg: libnvidia-compute-495:amd64: dependency problems, but removing anyway as you requested:
  Package libnvidia-compute-495:amd64 is to be removed.
  Package libnvidia-compute-550-server:amd64 which provides libcuda.so.1 is not configured yet.
  Package libnvidia-compute-535:amd64 which provides libcuda.so.1 is not installed.
  Package libnvidia-compute-550-server:amd64 which provides libcuda-11.5-1 is not configured yet.
  Package libnvidia-compute-535:amd64 which provides libcuda-11.5-1 is not installed.
Removing libnvidia-compute-495:amd64 (510.108.03-0ubuntu0.22.04.1) ...
Removing libnvidia-compute-510:amd64 (525.147.05-0ubuntu2.22.04.1) ...
Selecting previously unselected package libnvidia-cfg1-550-server:amd64.
(Reading database ... 219989 files and directories currently installed.)
Preparing to unpack .../00-libnvidia-cfg1-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-cfg1-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-common-550-server.
Preparing to unpack .../01-libnvidia-common-550-server_550.90.07-0ubuntu0.22.04.1_all.deb ...
Unpacking libnvidia-common-550-server (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-decode-550-server:amd64.
Preparing to unpack .../02-libnvidia-decode-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-decode-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-encode-550-server:amd64.
Preparing to unpack .../03-libnvidia-encode-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-encode-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-extra-550-server:amd64.
Preparing to unpack .../04-libnvidia-extra-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-extra-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-fbc1-550-server:amd64.
Preparing to unpack .../05-libnvidia-fbc1-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-fbc1-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-gl-550-server:amd64.
Preparing to unpack .../06-libnvidia-gl-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-gl-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-compute-utils-550-server.
Preparing to unpack .../07-nvidia-compute-utils-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-compute-utils-550-server (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-kernel-source-550-server.
Preparing to unpack .../08-nvidia-kernel-source-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-kernel-source-550-server (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-firmware-550-server-550.90.07.
Preparing to unpack .../09-nvidia-firmware-550-server-550.90.07_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-firmware-550-server-550.90.07 (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-kernel-common-550-server.
Preparing to unpack .../10-nvidia-kernel-common-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-kernel-common-550-server (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-dkms-550-server.
Preparing to unpack .../11-nvidia-dkms-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-dkms-550-server (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-utils-550-server.
Preparing to unpack .../12-nvidia-utils-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-utils-550-server (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package xserver-xorg-video-nvidia-550-server.
Preparing to unpack .../13-xserver-xorg-video-nvidia-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking xserver-xorg-video-nvidia-550-server (550.90.07-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-driver-550-server.
Preparing to unpack .../14-nvidia-driver-550-server_550.90.07-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-driver-550-server (550.90.07-0ubuntu0.22.04.1) ...
Setting up libnvidia-common-550-server (550.90.07-0ubuntu0.22.04.1) ...
Setting up libnvidia-extra-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Setting up nvidia-firmware-550-server-550.90.07 (550.90.07-0ubuntu0.22.04.1) ...
Setting up libnvidia-fbc1-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Setting up libnvidia-cfg1-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Setting up libnvidia-compute-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Setting up nvidia-kernel-source-550-server (550.90.07-0ubuntu0.22.04.1) ...
Setting up libnvidia-gl-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Setting up nvidia-kernel-common-550-server (550.90.07-0ubuntu0.22.04.1) ...
Created symlink /etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service → /lib/systemd/system/nvidia-hibern
ate.service.
Created symlink /etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service → /lib/systemd/system/nvidia-resume.serv
ice.
Created symlink /etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service → /lib/systemd/system/nvidia-resume.se
rvice.
Created symlink /etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service → /lib/systemd/system/nvidia-suspend.se
rvice.
Setting up xserver-xorg-video-nvidia-550-server (550.90.07-0ubuntu0.22.04.1) ...
Setting up nvidia-compute-utils-550-server (550.90.07-0ubuntu0.22.04.1) ...
Warning: The home dir /nonexistent you specified can't be accessed: No such file or directory
Adding system user `nvidia-persistenced' (UID 120) ...
Adding new group `nvidia-persistenced' (GID 124) ...
Adding new user `nvidia-persistenced' (UID 120) with group `nvidia-persistenced' ...
Not creating home directory `/nonexistent'.
Setting up nvidia-dkms-550-server (550.90.07-0ubuntu0.22.04.1) ...
INFO:Enable nvidia-srv
Loading new nvidia-srv-550.90.07 DKMS files...
Building for 6.8.0-40-generic
Building for architecture x86_64
Building initial module for 6.8.0-40-generic
Secure Boot not enabled on this system.
Done.
nvidia.ko:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/6.8.0-40-generic/updates/dkms/
nvidia-modeset.ko:
 - Original module
 - Installation
nvidia-drm.ko:
 - Original module
 - Installation
nvidia-uvm.ko:
 - Original module
 - Installation
nvidia-peermem.ko:
 - Original module
 - Installation
depmod...
Setting up libnvidia-decode-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Setting up nvidia-utils-550-server (550.90.07-0ubuntu0.22.04.1) ...
Setting up libnvidia-encode-550-server:amd64 (550.90.07-0ubuntu0.22.04.1) ...
Setting up nvidia-driver-550-server (550.90.07-0ubuntu0.22.04.1) ...
After reboot confirmation and cleanup:
Last login: Fri Sep  6 18:06:15 2024 from 192.168.0.13
[chuck@glockner ~.1998]$ nvidia-smi
Fri Sep  6 18:27:40 2024
| NVIDIA-SMI 550.90.07              Driver Version: 550.90.07      CUDA Version: 12.4     |
| GPU  Name                 Persistence-M | Bus-Id          Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |           Memory-Usage | GPU-Util  Compute M. |
|                                         |                        |               MIG M. |
|   0  Quadro P2200                   On  |   00000000:07:00.0 Off |                  N/A |
| 56%   45C    P0             21W /   75W |       2MiB /   5120MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|  No running processes found                                                             |
[chuck@glockner ~.1999]$ sudo apt autoremove -y
0 upgraded, 0 newly installed, 99 to remove and 0 not upgraded.
After this operation, 2,770 MB disk space will be freed.
(Reading database ... 220694 files and directories currently installed.)
Removing openjdk-8-jre:amd64 (8u422-b05-1~22.04) ...
Removing fonts-dejavu-extra (2.37-2build1) ...
Removing libaccinj64-11.5:amd64 (11.5.114~11.5.1-1ubuntu1) ...
Removing libatk-wrapper-java-jni:amd64 (0.38.0-5build1) ...
Removing libatk-wrapper-java (0.38.0-5build1) ...
Removing libbabeltrace1:amd64 (1.5.8-2build1) ...
Removing libsource-highlight4v5 (3.1.9-4.1build2) ...
Removing libboost-regex1.74.0:amd64 (1.74.0-14ubuntu3) ...
Removing libthrust-dev (1.15.0-1) ...
Removing libcub-dev (1.15.0-3) ...
Removing libcusolver11:amd64 (11.3.2.107~11.5.1-1ubuntu1) ...
Removing libnvblas11:amd64 (11.7.4.6~11.5.1-1ubuntu1) ...
Removing libcusolvermg11:amd64 (11.3.2.107~11.5.1-1ubuntu1) ...
Removing libcudart11.0:amd64 (11.5.117~11.5.1-1ubuntu1) ...
Removing libcufftw10:amd64 (11.1.1+~10.6.0.107~11.5.1-1ubuntu1) ...
Removing libcuinj64-11.5:amd64 (11.5.114~11.5.1-1ubuntu1) ...
Removing libcupti-dev:amd64 (11.5.114~11.5.1-1ubuntu1) ...
Removing libcupti-doc (11.5.114~11.5.1-1ubuntu1) ...
Removing libcupti11.5:amd64 (11.5.114~11.5.1-1ubuntu1) ...
Removing libcurand10:amd64 (11.1.1+~10.2.7.107~11.5.1-1ubuntu1) ...
Removing libcusparse11:amd64 (11.7.0.107~11.5.1-1ubuntu1) ...
Removing libdebuginfod1:amd64 (0.186-1build1) ...
Removing libdebuginfod-common (0.186-1build1) ...
Removing nsight-systems (2021.3.3.2~11.5.1-1ubuntu1) ...
Removing nsight-compute (2021.3.1.4~11.5.1-1ubuntu1) ...
Removing libqt5network5:amd64 (5.15.3+dfsg-2ubuntu0.2) ...
Removing libqt5dbus5:amd64 (5.15.3+dfsg-2ubuntu0.2) ...
Removing libqt5core5a:amd64 (5.15.3+dfsg-2ubuntu0.2) ...
Removing libdouble-conversion3:amd64 (3.1.7-4) ...
Removing libgl1-mesa-dev:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Removing libglvnd-dev:amd64 (1.4.0-1) ...
Removing libgles-dev:amd64 (1.4.0-1) ...
Removing libegl-dev:amd64 (1.4.0-1) ...
Removing libgail-common:amd64 (2.24.33-2ubuntu2.1) ...
Removing libgail18:amd64 (2.24.33-2ubuntu2.1) ...
Removing libgl-dev:amd64 (1.4.0-1) ...
Removing libgles1:amd64 (1.4.0-1) ...
Removing libglvnd-core-dev:amd64 (1.4.0-1) ...
Removing libglx-dev:amd64 (1.4.0-1) ...
Removing libgtk2.0-bin (2.24.33-2ubuntu2.1) ...
Removing libgtk2.0-0:amd64 (2.24.33-2ubuntu2.1) ...
Removing libgtk2.0-common (2.24.33-2ubuntu2.1) ...
Removing libipt2 (2.0.5-1) ...
Removing libnppial11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnpps11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnppicc11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnppidei11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnppif11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnppig11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnppim11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnppist11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnppisu11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnppitc11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing libnvjpeg11:amd64 (11.5.4.107~11.5.1-1ubuntu1) ...
Removing libnvrtc11.2:amd64 (11.5.119~11.5.1-1ubuntu1) ...
Removing libnvrtc-builtins11.5:amd64 (11.5.119~11.5.1-1ubuntu1) ...
Removing libnvtoolsext1:amd64 (11.5.114~11.5.1-1ubuntu1) ...
Removing libnvvm4:amd64 (11.5.119~11.5.1-1ubuntu1) ...
Removing libopengl-dev:amd64 (1.4.0-1) ...
Removing libopengl0:amd64 (1.4.0-1) ...
Removing libpcre2-16-0:amd64 (10.39-3ubuntu0.1) ...
Removing libvdpau-dev:amd64 (1.4-3build2) ...
Removing libx11-dev:amd64 (2:1.7.5-1ubuntu0.3) ...
Removing libxcb1-dev:amd64 (1.14-3ubuntu3) ...
Removing libpthread-stubs0-dev:amd64 (0.4-1build2) ...
Removing libsource-highlight-common (3.1.9-4.1build2) ...
Removing libtbb-dev:amd64 (2021.5.0-7ubuntu2) ...
Removing libtbb12:amd64 (2021.5.0-7ubuntu2) ...
Removing libtbbmalloc2:amd64 (2021.5.0-7ubuntu2) ...
Removing libxau-dev:amd64 (1:1.0.9-1build5) ...
Removing libxcb-icccm4:amd64 (0.4.1-1.1build2) ...
Removing libxcb-image0:amd64 (0.4.0-2) ...
Removing libxcb-keysyms1:amd64 (0.4.0-1build3) ...
Removing libxcb-render-util0:amd64 (0.3.9-1build3) ...
Removing libxcb-util1:amd64 (0.4.0-1build2) ...
Removing libxcb-xinerama0:amd64 (1.14-3ubuntu3) ...
Removing libxkbcommon-x11-0:amd64 (1.4.0-1) ...
Removing libxcb-xkb1:amd64 (1.14-3ubuntu3) ...
Removing libxdmcp-dev:amd64 (1:1.1.3-0ubuntu5) ...
Removing libxnvctrl0:amd64 (510.47.03-0ubuntu1) ...
Removing node-html5shiv (3.7.3+dfsg-4) ...
Removing nsight-compute-target:amd64 (2021.3.1.4~11.5.1-1ubuntu1) ...
Removing nsight-systems-target:amd64 (2021.3.3.2~11.5.1-1ubuntu1) ...
Removing ocl-icd-opencl-dev:amd64 (2.2.14-3) ...
Removing opencl-clhpp-headers (3.0~2.0.15-1ubuntu1) ...
Removing opencl-c-headers (3.0~2022.01.04-1) ...
Removing pkg-config (0.29.2-1ubuntu3) ...
Removing python3-blessings (1.7-1) ...
Removing qttranslations5-l10n (5.15.3-1) ...
Removing x11proto-core-dev (2021.5-1) ...
Removing x11proto-dev (2021.5-1) ...
Removing xorg-sgml-doctools (1:1.11-1.1) ...
Removing xtrans-dev (1.4.0-1) ...
Removing libcublas11:amd64 (11.7.4.6~11.5.1-1ubuntu1) ...
Removing libcublaslt11:amd64 (11.7.4.6~11.5.1-1ubuntu1) ...
Removing libnppc11:amd64 (11.5.1.107~11.5.1-1ubuntu1) ...
Removing openjdk-8-jre-headless:amd64 (8u422-b05-1~22.04) ...
Removing java-common (0.72build2) ...
Removing ca-certificates-java (20190909ubuntu1.2) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for ca-certificates (20230311ubuntu0.22.04.1) ...
Updating certificates in /etc/ssl/certs...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
updates of cacerts keystore disabled.
done.
Processing triggers for fontconfig (2.13.1-4.2ubuntu5) ...
[chuck@glockner ~.2000]$
Thanks for your assistance. I performed those steps and here is where I’m at:
kevin@plexmatrix:~$ nvidia-smi
Fri Sep  6 22:33:39 2024
|                                         |                        |               MIG M. |
|   0  NVIDIA GeForce GTX 1070 Ti     Off |   00000000:02:00.0 Off |                  N/A |
|  0%   46C    P0             29W /  180W |       0MiB /   8192MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|        ID   ID                                                               Usage      |
kevin@plexmatrix:~$ dpkg -l | grep ^ii | grep nvidia | awk '{print $2}'
No more references to 535! :slight_smile:
Also just verified that hw transcoding is working.
I now took it to the latest vetted driver from Ubuntu
[chuck@glockner ~.1999]$ nvidia-smi
Fri Sep  6 18:42:43 2024
| NVIDIA-SMI 550.107.02             Driver Version: 550.107.02     CUDA Version: 12.4     |
|                                         |                        |               MIG M. |
| 51%   42C    P0             25W /   75W |     210MiB /   5120MiB |      4%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A      5833      C   ...lib/plexmediaserver/Plex Transcoder        205MiB |
I’ll run it a bit but this seems really good so far
Been running the past several hours.
no glitches from 550.107.02
[chuck@lizum ~.2001]$ nvidia-smi
Sat Sep  7 19:47:42 2024
|                                         |                        |               MIG M. |
|   0  NVIDIA RTX 2000 Ada Gene...    On  |   00000000:01:00.0  On |                  Off |
| 30%   47C    P2             27W /   70W |     915MiB /  16380MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A      4598      G   /usr/lib/xorg/Xorg                            180MiB |
|    0   N/A  N/A      5427      G   /usr/bin/gnome-shell                           98MiB |
|    0   N/A  N/A      9738      G   gnome-control-center                          101MiB |
|    0   N/A  N/A     44682      C   ...lib/plexmediaserver/Plex Transcoder        522MiB |
[chuck@lizum ~.2002]$
How did you do that upgrade? If I do an apt upgrade, it doesn’t upgrade the 550 driver already installed.
first,
I wasn’t clear about something.
The headed drivers are upgraded quicker than the server drivers.
Servers , like ubuntu-server, are meant to upgrade slower and with greater caution being compute nodes.
Headed servers will update more quickly because of the path Linux is taking (its drive to be better at supporting gaming)
You can call out the specific version if you want ; which is what I did for everyone’s benefit.
Whether your 550.90.02 or 550.107.02 makes very little difference.
The next release (560) is where we will see the major change with nvidia drivers becoming more integral to the kernel (initramfs) than ever
Been running 560.35.03 for some time now. So far so good.
