PMS Linux 1.19.1.2645 Hardware Transcode Not Working
Noticed my CPU was running high and saw 2 users showing “Transcode” in the GUI, but not “(hw)”. Checked nvidia-smi and sure enough, nothing transcoding on the card. Maybe something with the latest driver on Ubuntu?
NVIDIA-SMI 440.82 Driver Version: 440.82 CUDA Version: 10.2
Logs (grep TPU):
Plex Media Server.log:Apr 11, 2020 20:46:51.440 [0x7eff29ffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/ou tpu t error
Plex Media Server.log:Apr 11, 2020 20:46:51.445 [0x7eff29ffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/ou tpu t error
Plex Media Server.log:Apr 11, 2020 20:46:51.450 [0x7eff29ffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/ou tpu t error
Plex Media Server.log:Apr 11, 2020 20:46:51.455 [0x7eff29ffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/ou tpu t error
Plex Media Server.log:Apr 11, 2020 20:46:51.460 [0x7eff29ffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/ou tpu t error
Plex Media Server.log:Apr 11, 2020 20:46:51.465 [0x7eff29ffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/ou tpu t error
Plex Media Server.log:Apr 11, 2020 20:46:51.470 [0x7eff29ffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/ou tpu t error
Plex Media Server.log:Apr 11, 2020 20:46:51.475 [0x7eff29ffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/ou tpu t error
Plex Media Server.log:Apr 11, 2020 20:46:52.187 [0x7eff9cff9700] DEBUG - TPU : hardware transcoding: enabled, but no hardware decode accelerator found
Plex Media Server.log:Apr 11, 2020 20:46:52.188 [0x7eff9cff9700] DEBUG - TPU : hardware transcoding: zero-copy support not present
Plex Media Server.log:Apr 11, 2020 20:46:52.188 [0x7eff9cff9700] DEBUG - TPU : hardware transcoding: final decoder: , final encoder:
Plex Media Server.log:Apr 11, 2020 21:00:13.982 [0x7eff62ffd700] DEBUG - NAT: UPnP, ge tPu blicIP didn’t find usable IGD.
Binary file Plex Media Server.log matches
I have the same problem, since this update plex is no longer working, no transcoding, everything goes bad, please fix it ASAP.
I have the same issue too.
Centos 7
Attached are my debug logs:
May 21, 2020 10:56:31.870 [0x7f4d5dffb700] DEBUG - Streaming Resource: Reducing playback quality for 1428kbps stream bitrate: video resolution to 720x406, audio channels to 2, quality to 20, disable audio DS as 2147483647kbps is > the 128kbps available
May 21, 2020 10:56:31.870 [0x7f4d5dffb700] DEBUG - Codecs: testing h264_nvenc (encoder)
May 21, 2020 10:56:31.871 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: testing API nvenc
May 21, 2020 10:56:31.871 [0x7f4d5dffb700] ERROR - [FFMPEG] - cu->cuCtxCreate(&hwctx->cuda_ctx, 4, cu_device) failed
May 21, 2020 10:56:31.871 [0x7f4d5dffb700] ERROR - [FFMPEG] -  -> CUDA_ERROR_INVALID_VALUE: invalid argument
May 21, 2020 10:56:31.871 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Unknown error occurred
May 21, 2020 10:56:31.871 [0x7f4d5dffb700] DEBUG - Codecs: testing h264 (decoder) with hwdevice vaapi
May 21, 2020 10:56:31.871 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: testing API vaapi
May 21, 2020 10:56:31.871 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error
May 21, 2020 10:56:31.871 [0x7f4d5dffb700] DEBUG - Codecs: testing h264 (decoder) with hwdevice nvdec
May 21, 2020 10:56:31.871 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: testing API nvdec
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] ERROR - [FFMPEG] - cu->cuCtxCreate(&hwctx->cuda_ctx, 4, cu_device) failed
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] ERROR - [FFMPEG] -  -> CUDA_ERROR_INVALID_VALUE: invalid argument
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Unknown error occurred
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - Scaled up video bitrate to 3885Kbps based on 1.500000x fudge factor.
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - Scaled maximum bitrate for resolution reduction to 1232Kbps.
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - MDE: Selected protocol dash; container: mp4
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - MDE: analyzing media item 217912
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - MDE: E11 - Morning Star: Direct Play is disabled
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - MDE: E11 - Morning Star: media must be transcoded in order to use the dash protocol
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - MDE: E11 - Morning Star: no direct play video profile exists for http/mkv/h264
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - MDE: E11 - Morning Star: no direct play video profile exists for http/mkv/h264/aac
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - Morning Star - video.bitrate limitation applies: 2590 > 1500
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - MDE: E11 - Morning Star: no remuxable profile found, so video stream will be transcoded
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - Codecs: testing h264_nvenc (encoder)
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: testing API nvenc
May 21, 2020 10:56:31.872 [0x7f4d5dffb700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
May 21, 2020 10:56:31.873 [0x7f4d5dffb700] DEBUG - Codecs: testing h264 (decoder) with hwdevice vaapi
May 21, 2020 10:56:31.873 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: testing API vaapi
May 21, 2020 10:56:31.873 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error
May 21, 2020 10:56:31.873 [0x7f4d5dffb700] DEBUG - Codecs: testing h264 (decoder) with hwdevice nvdec
May 21, 2020 10:56:31.873 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: testing API nvdec
May 21, 2020 10:56:31.873 [0x7f4d5dffb700] ERROR - [FFMPEG] - cu->cuCtxCreate(&hwctx->cuda_ctx, 4, cu_device) failed
May 21, 2020 10:56:31.873 [0x7f4d5dffb700] ERROR - [FFMPEG] -  -> CUDA_ERROR_INVALID_VALUE: invalid argument
May 21, 2020 10:56:31.873 [0x7f4d5dffb700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Unknown error occurred
same problem
Here’s the steps i took to fix the issue on Centos: HW Transcode, Linux/Docker/Intel QVS/Nvidia P2000 - Unable to hw transcode
Probably something along the following lines for Ubuntu:
sudo -i
service docker stop
apt-get purge nvidia*
apt-get clean
apt-get update
apt install nvidia-driver-440
reboot
