I’ve just purchased a Synology DS918+ NAS. I thought that Plex supported hardware transcoding on this device, but I’m not able to enable it. I think I’ve met all of the requirements:
Intel CPU with Quick Sync (Intel Celeron J3455 - apollolake)
64-bit architecture and 64-bit Linux (Linux media-server 4.4.15+ #15217 SMP PREEMPT Wed Dec 20 18:19:46 CST 2017 x86_64 GNU/Linux synology_apollolake_918+)
Plex Media Server 1.11.0.4666
Active and logged-in Plex Pass subscription
Advanced options enabled
But, my “Settings > Server > Transcoder” settings page does not include a “Use hardware acceleration when available” option.
I know that originally, a special version of Plex Server had to be downloaded, but I think this capability is included in anything afer 1.9.3 - is that true?
I have the same configuration since a couple of weeks and I am experiencing the same issue.
I tried following the steps, however I still do not have the option. The server seems to be running under the plex user, as it can read and write the appropriate folder appointed for media, however I am not too sure how do I double check this (tried task manager and ps -A -all on PuTTy with no luck - the user is not reported), the user is part of the “video” group as well.
Would you please recreate the problem, let it play for a few seconds, stop playback, then gather the logs? Settings - Server - Help - Download Logs and attach the ZIP file?
Where did you download PMS from? Synology? or directly from Plex? If you downloaded from Synology, they only offer the 32 bit version which will not work for hardware transcoding.
Regarding the ps command: ps -ef not ps -A The username is reported in output column 1.
User plex 's default group is users as per Synology requirement. It is added to the video group in order to access the GPU.
First installation was done by Synology, then I have updated from the Plex server page, downloading the plk directly and installing it manually. However, this suggestion about the 32 bit version did the trick! I actually had x86 installed, so I downloaded x64 from the download page, installed it, and woila, the option is now there! Thank you
Confirmed - it runs under plex. Thanks for the tip, learning something new every day!
I can confirm I have set it like this, plex is basically in both the groups, users and video.
Thanks @ChuckPA. I’m getting back to this thread quite late, but your suggesting regarding 32-bit vs 64-bit fixed the issue for me.
I had actually upgraded from a DS415play (32-bit) to a DS918+ (64-bit). But, the version of Plex on the system was still 32-bit. I downloaded and installed the 64-bit version, and now it works fine.
Is there any way to see if an active transcoding is using hardware or software (I have a DS1817+, 2.4 GHz, 4 cores, DSM 6.1.4, Plex 1.11.0.4666 and have enabled the option in Server->Transcoder->Advanced)?
