Hardware Transcoding Plex Docker Intel N5105 not working
I have the Asustor AS6706T NAS (Intel Celeron N5105 with Quick Sync support) and installed Plex Media Server with a docker container.
PMS was installed using this guide with docker compose:
The Plex Media Server itself is running as expected, i can see my whole library. But when i play a 1080p movie on my phone and transcode it to 480p for testing it does not use hardware transcoding and my cpu goes to 100%.
I have Plex Pass and enabled Hardware transcoding in the settings.
Here is my /dev/dri folder:
RenderD128
Furthermore i passed through the /dev/dri folder to the Plex container, but hardware transcoding is not working for me right now.
Here is my docker compose:
I found this in the Plex Media Server log:
Debug
Can somebody help me to get the hardware transcoding to work? I have to say i´m new to Linux.
Did you symlink the /dev/dri?
And, are you running portainer?
I have Portainer running. What do you mean by symlink exactly?
I ran the command /dev/dri:/dev/dri under devices in my docker compose.
That’s good news!
It’s a required step in the workaround I had to use to get hardware transcoding working on my NAS (reminder: not a Synology, but a TerraMaster. But in docker, the process should be very similar I would bet).
Read the following tutorial here:
https://forum.terra-master.com/en/viewtopic.php?f=51&t=2236&p=12028&hilit=Symlink+dev%2Fdri#p12028
Paying special attention to:
The steps after the following paragraph
The main point where things may be different is in regard to the needed symlink location…
As I’m unfamiliar with the layout of the Synology OS, there may be variations that you have to account for in the process.
But the tutorial by Sportswook is pretty detailed (enough to give you a pretty good idea of what needs to be done (both in the Linux OS, and also in docker [via portainer settings])).
DAC_READ_SEARCH was one of the key settings in docker that got me over the hump.
Thank you for your great answer, I will take a look later :grinning:
