Edit: This happens w PMS on Haswell to Coffee Lake iGPU. It happens in Linux (Synology but not Ubuntu 18.10) and Windows PMS. It happens in all of the last months worth of beta versions. It is NOT the expected superiority of SW over HW image quality you see with most of these bitrate samples. It is one specific bitrate 20 combined with MAX transcode rate in the web client looks like garbage. It is an encode problem, not a decode problem. Devs please notice!
Server Version#: Synology intel 64 bit and windows 64bit 1.15.1.707
Player Version#:web 3.83.1 in chrome
This is reproducible using file jellyfish-20-mbps-hd-hevc
from http://jell.yfish.us/
Severe blocking, visual quality is far inferior to the same clip with software decode (slight is expected) quality is also far inferior to the same file in 3 or 10 mbps versions. Strangely I didn’t experience it with the 25,30,35,45, but it WAS there, to a lesser degree, with the 40mbps sample.
I confirmed this on a Synology server Linux, with Intel e3-1275 v3 HW transcode enabled, and on Windows 10 w e3-1275 v3 HW transcode enabled, as well as a Dell XPS with Intel 7200u HW transcode enabled.
I confirmed in the dashboard that the only time I saw the low-quality image there was hw encode and hw decode occurring.
Plex Media Server Logs_2019-02-24_14-25-41.zip (391.2 KB)
Plex Media Server Databases_2019-02-24_14-27-26.zip (42.5 KB)
(Edit to note the fact that PMS on ubuntu does not have the issue)
