Hi all… I’m not too savvy about the PCIe ports. My TVS-673e I think has PCIe 3.0 x8 ports and all the cards that I see including the MSI GTX1050Ti LP that you are saying are x16. I don’t know if I can buy a x16 and it will fit the QNAP. Can you be a bit more specific of which cards did you buy, maybe a New Egg link or Amazon?
Thank you pcamargo, I was thinking about buying something more powerful (and a bit affordable) and looked up the P600 & P620. At the end, they had the same amount of concurrent transcodings (3) and I ended up buying the P400.
So. I ended up getting a nvidia p2000 instead of the p400. I was not able to get QTS to unload the transcoding to that card in a docker. QTS wouldn’t mount the card, in my experience.
So I ended up removing the QTS and loaded Unraid on my qnap.
It will be interesting to see how much you can extract from the P2200 before your CPU maxes out. I have found that even with the P400 doing the transcode, Plex still demanded too much from the CPU, while Emby was a lot lighter on it. Which one do you use?
