Workout videos as tv show pulling PMS as agent. For MKV files it appears Plex will not use file names for episodes, is there a way to force it to or a tagging scheme that will work from the file side? As I have a bunch of those, I was mainly looking for a way to automate the process instead of going into each episode of each “show” and manually changing the titles of episodes. I already went through and changed everything to a “TV Show” structure on the actual files. Plex does “arrange” properly, but is giving me “episode 1” or using a “created on” date instead of the actual titles.
I have been looking for awhile now and have not found anything so any ideas or direction anyone could provide would be fantastic.
Is that actually showing episode titles in Plex though? I have the show structure right, just want Plex to pull episode titles instead of episode 1, 2, 3.
Yes. The first picture is from plex. Plex added the title I embedded automatically. I made no edits in plex.
See. Look at episode 111. It displays the title I embedded into the MP4 file(second picture)
You cannot get rid of the “Episode xxx” underneath it though.
I was trying to provide other options.
But yes, I was only confirming your comment. There is no way around it. If you have MKV files, you cannot use embedded metadata.
