Has TV unwatched view changed since 1.1.0?
I wrote a separate post regarding how unwatched TV shows are not showing correctly since 1.1.0. Question to the group as I don’t recall - in Plex Web and Plex Media Player for OS X the TV unwatched view, the correct number of unwatched is in the summary, but when listing a specific season, all the episodes are displayed (even ones that were watched). You can see the unwatched markers to know which ones are truly unwatched. Is this the way it always worked?? I thought only the truly unwatched episodes were displayed? At first I thought this was a DLNA thing with my WDTV - but it appears the unwatched query doesn’t pull down to the episode level only at the season level
This problem appeared with Plex Media Server since update 1.1.0.2611. Prior to the update all previous PMS versions up to and including 1.0.3.2461 showed unwatched items via the DLNA PMS. I have uninstalled Plex on Synology DS412+ and then re-installed each PMS update up to 1.0.3.2461 [after uninstalling the previous], and unwatched items works fine. Once PMS update 1.1.0.2611 is installed, unwatched items ceases to work. Hopefully this information is of use to someone. My only resolution at this time is to stick with 1.0.3.2461.
Great - this was fixed in 1.3.0!
