I’ve been using the Hauppauge HVR-1600 combo tuner since December with no problems. When I opened Plex recently the tuner and program listing were no longer there. I tried to set it up again but Plex would not recognize the tuner. I used to use Sage so I opened it up to see if it saw the tuner. It did. I’m not sure what to do now. The two things I did recently do were update the software and scan the drive. I tried reverting to an older version of the program with no luck. I had scanned the hard drive recently and it did correct a number of errors. Any ideas?
