HAUPPAUGE WinTV-DualHD Dual USB 2.0 for 4 recordable channels?
Can I use TWO HAUPPAUGE WinTV-DualHD Dual USB 2.0 for 4 recordable channels ?
Currently I use one and it records two channels perfects, just wondering if two of the same tuner will merge seamlessly into the channel guide or I have to do another channel search too. Thank you
Server Version#:
Tuner Make/Model: WinTV-DualHD Dual USB 2.0
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I have 2 HDHomerun’s (totaling 6 tuners) 1. Extend (2 tuners and transcoding in the unit) and 2. Quattro (4 Tuners) and have never had an issue with the integration of them into Plex.
I’ve had all 6 tuners running different channels 2 recording and no issues. The only issue I could see is the PC recording 4 tuners at once, but that would be a computer issue not Plex.
