Only Able to Use 1 Tuner
Server Version#:1.14.1.5488
Player Version#:Web
I have been hunting for people having this similar issue for an hour and do not see any post about this exact issue. I am sorry if I missed a previous post. My PlexDVR Live TV function works but I can only get 1 tuner on the Haupage WinTV-DualHD USB device working in Plex. Once one of the two tuners available is in use I am unable to stream LiveTV or record using the second tuner. It may just be me not really understanding how OTA TV works :smile:.
This is what I see in the Plex DVR settings.
And this is what I get when trying to watch a different channel. Regardless of user or device.
Tuner%20Error
If I stop the current recording or if I close the session of live tv being watched then this problem goes away. I am always able to use up to 1 of the 2 tuners in the device. I am trying to use just 1 antenna and am wondering if that is the problem. Thanks so much for any advice you may have.
Can’t relate, works with 2+ tuners using HDHomeRun EXPAND (device can run up to 4 streams simultanious).
Same here.
One simultaneous view or record, neither parallel recording of two programs nor record / view in SD and HD… it´s really dangerous because plex allows two parallel recordings so one of your records will be crippled. :frowning:
Hardware is Hauppauge WinTV DualHD USB, problem persists since purchase mid 2018.
