Server Version#: 1.24.1.4931
Tuner Make/Model: Hauppauge WinTV-dualHD
Hello,
i’m using 2 seperate Hauppauge WinTV-dualHD USB hooked up to the same antenna using the same EPG provider and the same channel selection, but PLEX is only using one of the 2 WinTV’s.
If I try to schedule recordings of more than 2 channels at once I get a messagebox saying there is a collision and I have to select what recordings I prioritize.
So basically PLEX stops me from using more than 2 tuners at once but there are 4 tuners available.
I’ve tried to delete the DVR configuration and do device selection and channel assortiations again - same result.
PLEX is only using the first of the 2 DVB-T2 USB sticks.
Is there a trick to use more than one device?
