I am attempting to build a Plex media server with unRAID. I have a Hauppauge WinTV-quadHD card that shows Plex support on the box. Plex cannot see the card from the DVR setup screen. Any ideas? I something else needed?
-unRAID 6.4.0
-Plex Server Version 1.11.0.4666 (LinuxServer.io docker image)
Sorry to revive an old thread but your solution worked for me…temporarily. I just installed the WinTV Quad after following your advice and it worked great. Channels detected, shows recorded, etc. When I looked at the server 12 hrs later, Plex was offline. When restarted, it gives me an ‘execution error’ and won’t start. If I remove the Extra Parameter (–device=/dev/dvb/), it will start but doesn’t see the WinTV. Any chance you have any insight on this? I’m wondering if the tuner card died?? Thanks!
