Server Version#: 1.18.7.2457
Player Version#: 4.22.2
Tuner Make/Model: WinTV QuadHD
lspci: Conexant Systems, Inc. CX23887/8 PCIe Broadcast Audio and Video Decoder with 3D Comb (rev 04)
Hi everyone,
since a few days I’ve changed my server setup from a Proxmox virtualisation server with 2 VMs (FreeNAS, Ubuntu). In Ubuntu I had three docker container with Plex and TVHeadend along with Antennas (TVHproxy) running. The WinTV QuadHD was passthroughed to the Ubuntu VM and everything worked with a few hickups.
Now I changed everything to Unraid and since then the DVR stuff is a mess. Sometimes it works, most of the times not. Nearly the same setup as before: Plex, TVHeadend, Antennas (TVHproxy). To get the card running on Unraid I used UnraidDVB.
Starting a stream in Plex leads to Sender konnte nicht eingestellt werden. Bitte Empfänger oder Antenne prüfen.
or in english:
The station could not be tuned in. Please check receiver or antenna. (Google translate)
Unraid Informations
Linux Kernel Version: 4.19.98
DVB Version: LibreELEC
Driver Version: 1.4.0
DVB Kernel: Detected
DVB Adapter Drivers: Detected
DVB Adapter 0: Silicon Labs Si2168
DVB Adapter 1: Silicon Labs Si2168
DVB Adapter 2: Silicon Labs Si2168
DVB Adapter 3: Silicon Labs Si2168```
Syslog
Mar 6 21:12:38 Unraid kernel: si2168 6-0066: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
Mar 6 21:12:39 Unraid kernel: si2168 6-0066: firmware version: B 4.0.25
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: mpeg risc op code error
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: TS2 C - dma channel status dump
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: init risc lo : 0xff1f9000
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: init risc hi : 0x00000000
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: cdt base : 0x000108d0
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: cdt size : 0x0000000a
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: iq base : 0x00010670
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: iq size : 0x00000010
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: risc pc lo : 0xff1f9048
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: risc pc hi : 0x00000000
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: iq wr ptr : 0x000041a4
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: iq rd ptr : 0x000041a8
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: cdt current : 0x000108e8
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: pci target lo : 0xff6f8000
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: pci target hi : 0x00000000
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cmds: line / byte : 0x00000000
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: risc0:
Mar 6 21:12:40 Unraid kernel: 0x1c0002f0 [ write sol eol count=752 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: risc1:
Mar 6 21:12:40 Unraid kernel: 0xff6f8000 [ INVALID sol eol irq2 irq1 22 21 19 18 cnt1 cnt0 resync count=0 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: risc2:
Mar 6 21:12:40 Unraid kernel: 0x00000000 [ INVALID count=0 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: risc3:
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: (0x00010670) iq 0:
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: (0x00010674) iq 1:
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: (0x00010678) iq 2:
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq 3: 0xff6f82f0 [ arg #1 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq 4: 0x00000000 [ arg #2 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: (0x00010684) iq 5:
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq 6: 0xff6f8bc0 [ arg #1 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq 7: 0x00000000 [ arg #2 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: (0x00010690) iq 8:
Mar 6 21:12:40 Unraid kernel: 0x70000000 [ jump count=0 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq 9: 0x1c0002f0 [ arg #1 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq a: 0xff6f8000 [ arg #2 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: (0x0001069c) iq b:
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: (0x000106a0) iq c:
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq d: 0xff6f82f0 [ arg #1 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq e: 0x00000000 [ arg #2 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: (0x000106ac) iq f:
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq 10: 0x679edc4d [ arg #1 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: iq 11: 0x6ccf8524 [ arg #2 ]
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: fifo: 0x00006000 -> 0x7000
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: ctrl: 0x00010670 -> 0x106d0
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: ptr1_reg: 0x00006420
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: ptr2_reg: 0x000108e8
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cnt1_reg: 0x00000013
Mar 6 21:12:40 Unraid kernel: cx23885: cx23885[1]: cnt2_reg: 0x00000007
Mar 6 21:12:45 Unraid kernel: si2168 6-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
Mar 6 21:12:46 Unraid kernel: si2168 6-0064: firmware version: B 4.0.25
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: mpeg risc op code error
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: TS1 B - dma channel status dump
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: init risc lo : 0xffca3000
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: init risc hi : 0x00000000
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: cdt base : 0x00010870
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: cdt size : 0x0000000a
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: iq base : 0x00010630
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: iq size : 0x00000010
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: risc pc lo : 0xffca3048
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: risc pc hi : 0x00000000
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: iq wr ptr : 0x00004194
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: iq rd ptr : 0x00004198
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: cdt current : 0x000108b8
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: pci target lo : 0xfe5c0000
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: pci target hi : 0x00000000
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cmds: line / byte : 0x00000000
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: risc0:
Mar 6 21:12:47 Unraid kernel: 0x1c0002f0 [ write sol eol count=752 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: risc1:
Mar 6 21:12:47 Unraid kernel: 0xfe5c0000 [ INVALID sol eol irq2 22 20 19 18 count=0 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: risc2:
Mar 6 21:12:47 Unraid kernel: 0x00000000 [ INVALID count=0 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: risc3:
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: (0x00010630) iq 0:
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: (0x00010634) iq 1:
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: (0x00010638) iq 2:
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq 3: 0xfe5c02f0 [ arg #1 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq 4: 0x00000000 [ arg #2 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: (0x00010644) iq 5:
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq 6: 0xfe5c0bc0 [ arg #1 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq 7: 0x00000000 [ arg #2 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: (0x00010650) iq 8:
Mar 6 21:12:47 Unraid kernel: 0x70000000 [ jump count=0 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq 9: 0x1c0002f0 [ arg #1 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq a: 0xfe5c0000 [ arg #2 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: (0x0001065c) iq b:
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: (0x00010660) iq c:
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq d: 0xfe5c02f0 [ arg #1 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq e: 0x00000000 [ arg #2 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: (0x0001066c) iq f:
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq 10: 0xff6f8000 [ arg #1 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: iq 11: 0x00000000 [ arg #2 ]
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: fifo: 0x00005000 -> 0x6000
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: ctrl: 0x00010630 -> 0x10690
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: ptr1_reg: 0x00005d80
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: ptr2_reg: 0x000108b8
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cnt1_reg: 0x0000001c
Mar 6 21:12:47 Unraid kernel: cx23885: cx23885[1]: cnt2_reg: 0x00000001```
Does someone know what I can do to get it back to working?
