Server Version#:1.30.0
Player Version#: Website
I have constant issues in my series library that he is either not displaying entire season or he is making 40 season on a show that only has 20 seasons.
So I looked for solution and found out that you can hardwire everything with plexmatch file.
I decided to write a little app that goes through every folder and generates the plexmatch files. However I struggle a bit with the plexmatch syntax.
https://support.plex.tv/articles/plexmatch/
What I need is an example of a plexmatch file that is sitting directly inside of the show folder (so above the season folders).
I tried to set it up like this:
se: 1: ep: 1: Season 1/4sj-witcher-1080p-hdr-s01e01.mkv
se: 1: ep: 2: Season 1/4sj-witcher-1080p-hdr-s01e02.mkv
se: 1: ep: 3: Season 1/4sj-witcher-1080p-hdr-s01e03.mkv
se: 1: ep: 4: Season 1/4sj-witcher-1080p-hdr-s01e04.mkv
se: 1: ep: 5: Season 1/4sj-witcher-1080p-hdr-s01e05.mkv
se: 1: ep: 6: Season 1/4sj-witcher-1080p-hdr-s01e06.mkv
se: 1: ep: 7: Season 1/4sj-witcher-1080p-hdr-s01e07.mkv
se: 1: ep: 8: Season 1/4sj-witcher-1080p-hdr-s01e08.mkv
se: 2: ep: 1: Season 2/The Witcher (2 x 1) - The Witcher - Flg. 1 Ein Körnchen Wahrheit.mkv
se: 2: ep: 2: Season 2/The Witcher (2 x 2) - The Witcher - Flg. 2 Kaer Morhen.mkv
However he does not like this. Season 2 is not showing up in the web player. So my question is what do i have to change. I want one plexmatch file for each tv show that wires all season and episode inside.
