.plexmatch not helping scanner mismatch
Server Version#: 1.25.9.5721
So I have some episodes of Boruto all in the same folder
For some reason, the Plex TV Series Scanner is detecting the majority of these episodes as Season 2 (despite there not even being a season 2, it uses absolute numbering), while only some of them as Season 1. They are all episodes 207+ so no episodes before episode 200.
Not sure what is going on here, tried multiple things like putting it in a season 1 folder, putting dummy files in a season 2 folder to differentiate it, and then the new server update was released with the .plexmatch files. So I tried to make it so that this whole folder is recognised as Season 1:
This still changes nothing. The only thing that works are the episodes I specified, but a new episode releases each week and I don’t want to do that. Shouldn’t specifying “Season: 1” not make every episode in that folder from Season 1? Thoughts :thinking:?
And your library are using the new native Plex agent?
And if so, do a Plex Dance and after that, upload a zip with your logs
Yes, I am using the new Plex Agent.
Plex Dance was completed, unfortunately, nothing changed.
Here are the logs:
Plex Media Server Logs_2022-04-09_00-50-57.zip (3.5 MB)
Yes, but episodes can’t be digested as S01E238 when the filename only contains 238
So either keep specifying ep: in the .plexmatch file or change the actual filename
