HD upgrade stops video playing
I recently replaced a 10TB HD with A 20TB, I copied all of the files, and everything worked fine. I later discovered that any new file wouldn’t play, the counter went to 30 sec. and stopped, nothing else is different. I also deleted the library and re scanned.
Adding some details about what kind of server and operating you’re using certainly helps.
Here is a way to do such a kind of operation on Windows without side effects:
  1. shut down Plex server or disable automatic and periodic library updates
  2. add the new hard drive
  3. copy the data, retaining all folder names and file names
  4. swap the drive letters of old and new hard drives Change a drive letter | Microsoft Learn
  5. remove old drive, start Plex server
Done this way, Plex won’t even notice that something has changed.
If the whole incident isn’t too long ago, you can restore a Plex database snapshot from before, then perform the above procedure.
https://support.plex.tv/articles/202485658-restore-a-database-backed-up-via-scheduled-tasks/
