HD videos not working on .27
I have a raspberry pi model A with 16GB SD card in it. Cat5e to a verizon router. HDMI 1.4 connected to a Onkyo’s AVX-290 thats connected to a Optoma Playtime LED Gaming Projector PT105 and I cannot play HD video's. I am also running version .27 of rasplex.
I have tried fully cache by scrolling through all files. I have tried making my output 480p and steaming a 720p or 1080p video to see if could handle the streaming the down converted video and that did not help.
Typically is plays for 5-15 seconds, then the video freezes while audio continues, then audio stops, it quick reboots with a cec error.
Is this a known bug or is anything else I should try doing?
Are the HD videos using DTS audio?
Try transcoding also
I am using dts and dolby audio because my reciever can decode it, should I not?
I'll also try force transcoding over the network, I think that is what you meant.
Thanks for the reply and all the hard work.
Resolved in 0.1.30?
No, actually worse. I have tried 2 different sd cards, and 2 differ raspberry pi A's. I also tried .29 and .28. All fresh installs with the windisk imager.
I can watch SD shows but no hd movies still. I have tried with and without dts, dolby, force transcoding on the network capped at 8,10, and 12mb/s. I have tried with making my output 720p and 600x800 as well.
In addition, music stopped playing. I attached a video of what happens.
https://www.youtube.com/watch?v=Cma1unwNbNA
Pic of the popup.
https://dl.dropbox.com/u/4312731/2002-12-08%2012.00.00-3.JPG
Unsure of how to get the log file for you.
To get the log, what you can do is use SSH client like Putty if you are under windows.
Then log in using plexuser/rasplex credentials.
Once you are logged in, the log file is located in /storage/.plexht/temp/plexhometheater.log
Grab it and try to pastebin the log, that would probably help.
Also if you can get the media codec information with something like mediainfo, it could give some information.
Disconnected: No supported authentication methods available (server sent: publickey, keyboard-interactive)
I double checked preferences and I have ssh enabled on boot.
Rebooting the server fixed hd playback. However music still gives me the weird results like in the video.
