HDHomeRun CONNECT Quatro not recording
Server Version#: 1.18.4.2171
Hi, I’m a bit stumped here. I have 1.6TB of free space for Plex, and I tried testing the DVR Feature to see how much space I will need in the future. however on each and every occasion I have tried to record a show I get one of two error messages.
  1. Cannot record airing in the past.
  2. There was not enough free disk space to start the recording.
I have checked and there is 1.6TB of free space, so that’s not the issue, and I have checked the write permissions on the HDD and every folder has Custom Read & Write Access.
I don’t know where I’m going wrong, I have included screenshots of my issue.
Any help is much appreciated.
With regards to the space requirements, it is probably the transcoder temp directory area that does not have adequate space - checks are done for both - the target location and the temporary transcode area
For the other error, would need server logs covering the time of recording and with debug logging not dusabled
Here are my logs. hope this helps.
thanks again.
Plex Media Server Logs_2020-01-14_01-06-10.zip (6.8 MB)
Not enough space/permissions, can’t write to TV location.
Jan 13, 2020 03:06:56.567 [0x70000f084000] DEBUG - Grabber: checking for 21317 MB of available disk space in grab path and transcode cache path
Jan 13, 2020 03:06:56.568 [0x70000f084000] DEBUG - IsOnSameVolume: failed to stat "/Volumes/MEDIA/PLEX/TV/.grab": No such file or directory
Jan 13, 2020 03:06:56.568 [0x70000f084000] ERROR - Failed to calculate available disk space for path '"/Volumes/MEDIA/PLEX/TV/.grab"': 2 (No such file or directory)
Jan 13, 2020 03:06:56.568 [0x70000f084000] WARN - Low disk space: 20.82GB source file, 375.34GB capacity, 168.8MB available on "/Users/xander/Library/Caches/PlexMediaServer/Transcode/Sessions"
Jan 13, 2020 03:06:56.568 [0x700010373000] DEBUG - Subscription: Failed to resolve subscription for movie 'guid: plex://movie/5db3f60b102c9c001fcd4d54 ratingKey: plex%3A%2F%2Fmovie%2F5db3f60b102c9c001fcd4d54 thumb: http://cps-static.rovicorp.com/2/Open/BGC_701/Program/29705197/NiceGuys_final_ss.jpg title: The Nice Guys type: 1 year: 2016' to library item
Jan 13, 2020 03:06:56.568 [0x700010373000] DEBUG - Grabber: checking for 21317 MB of available disk space in grab path and transcode cache path
Jan 13, 2020 03:06:56.569 [0x70000f084000] ERROR - Grabber: Not enough free space in "/Users/xander/Library/Caches/PlexMediaServer/Transcode/Sessions"
Jan 13, 2020 03:06:56.569 [0x70000f084000] DEBUG - Grabber: Operation for 'Selection of BBC World Service Programmes - Selection of BBC World Service Programmes' on channel 704 completed with status error (There was not enough free disk space to start the recording)
Jan 13, 2020 03:06:56.569 [0x70000f084000] DEBUG - Activity: Ended activity 717c1024-bc28-4626-a0b8-e9b88200b877.
Jan 13, 2020 03:06:56.569 [0x700010373000] DEBUG - IsOnSameVolume: failed to stat "/Volumes/MEDIA/PLEX/Film/.grab": No such file or directory
Jan 13, 2020 03:06:56.569 [0x700010373000] ERROR - Failed to calculate available disk space for path '"/Volumes/MEDIA/PLEX/Film/.grab"': 2 (No such file or directory)
Jan 13, 2020 03:06:56.569 [0x70000f084000] DEBUG - Activity: updated activity 468b2571-7edd-4bf1-9ff0-5b2a1fcdcba8 - completed 100.0% - Refreshing Sub
Jan 13, 2020 03:06:56.569 [0x70000f084000] DEBUG - Activity: Ended activity 468b2571-7edd-4bf1-9ff0-5b2a1fcdcba8.
Jan 13, 2020 03:06:56.570 [0x700010373000] WARN - Low disk space: 20.82GB source file, 375.34GB capacity, 168.8MB available on "/Users/xander/Library/Caches/PlexMediaServer/Transcode/Sessions"
Jan 13, 2020 03:06:56.570 [0x700010373000] ERROR - Grabber: Not enough free space in "/Users/xander/Library/Caches/PlexMediaServer/Transcode/Sessions"
Jan 13, 2020 03:06:56.570 [0x70000f084000] ERROR - Grabber: Starting media grab failed.
Jan 13, 2020 03:06:56.570 [0x700010373000] DEBUG - Grabber: Operation for 'The Nice Guys (2016)' on channel 059 completed with status error (There was not enough free disk space to start the recording)
Might need a database repair
Jan 13, 2020 17:30:04.328 [0x70000f6a8000] ERROR - SQLITE3:0x10c00ff08, 13, statement aborts at 142: [select distinct grandparents.id as metadata_items_grandparents_id,grandparents.title as metadata_items_grandparents_title,grandparents.user_thumb_url as metadata_items_grandparents_us
Jan 13, 2020 17:30:04.329 [0x70000f6a8000] ERROR - Soci Exception handled: sqlite3_statement_backend::loadRS: database or disk is full
Am I right in saying the DVR is trying to save it’s recordings to my Mac HDD and not the external HDD, where Plex media is kept.
Partially, for a Live TV & DVR recording Plex writes to two locations. Segment files sent from the tuner are written to the Transcoder directory, if you have left your “Transcoder temporary directory” setting blank then Plex will write to where the Plex data is stored. Concurrently it concatenates the segment files into the .grab file located in the TV/Movie directory you have set for the TV/Move libraries to become the finished recording that it moves to the final location.
First step would be to change the transcoder directory to somewhere on your 1.6TB drive and free up some space on the default or relocate the Plex data. Second is sorting out the permissions on the 1.6TB drive, I am not familiar with MacOS so I will leave that for someone else to answer.
