HDHomerun Extend Live TV stream transcoding with hardware encoding enabled on Extend
Server Version#: 1.21.0.3616
Tuner Make/Model: HDHomerun Extend
Guide/Lineup name: n/a
Using XMLTV?: no
Channel number/Name: n/a
Something is not right. I have a HDHomerun Extend that has a built-in hardware transcoding ability, but no matter what I do in PLEX or the HDHomerun setup, PLEX always wants to transcode the stream when watching Live OTA TV. Is there a way to reduce the overhead of the re-encode in PLEX to a setting on the HDHomerun?
From what I see, it looks like all live streams are transcoded… (maybe to reduce file size), but that should be an option that I would set. The PLEX activity shows up as ā€˜recording’ even though I am only watching a live stream.
Current transcoder set up on HDHomerun Extend - Heavy
Current transcoder set up on Device Settings - Highest
Any assistance is appreciated. And for the record I have successfully DVRed all seasons of Magnum PI from Charge using this set up.
