HDHR Dual on Plex - problems with DVB-C
Hi. i’m using Plex on a windows 10 platform, and want to set up my HDHR Dual for Livetv through DVB-C
Plex can easily find the tuner during setup, and connect to it, but unfortunately i am not able to choose DVB-C, only “antenna”.
When i select “antenna”, i get a list of selections for DVB-T providers in my area, but i’m using DVB-C, There is no DVB-T signals through my provider.
The HDHR tuner has been set up through HDHR setup application to EU-cable, and i can easily see all channels in the HDHR application, and it also works fine in EMBY, but i want to use PLEX :slight_smile:
I wonder what i’m doing wrong, since Plex only recognizes DVB-T on the device ?
( i have 2 HDHR dual tuners - 1 is online and 1 i’m saving 1 for spare) I’ve tried with both devices and get the same result - only DVB-T (or Antenna) is selectable :confused:
I forgot to add the TV-Tuner log :frowning:
But apparently, Plex can’t find the C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini
And i can confirm that it does not exist :frowning:
Hi fireflite, I am having the same problem with my HD Home Run… here is my post:
Hi all I am new here and I have had my Plex server running for about 5 weeks now. I have just brought a Plex Pass and I am now adding Live TV with a Silicon Dust HD Home Run, for some reason the Plex is freezing when I click ok to confirm the program guild the little orange circle just keeps on going around, I have left it for about 15 minutes and its still going.
Can anyone help at all please.
Windows 8.1
Plex Version 1.9.7.4460
Silicon Dust - HD HomeRun
DEBUG - * file_tuner::get_stream_file. File C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
Did you manage to resolve this, I am suffering from the same issue suddenly
I tried to create a transponder.ini for Plex, and i can see it in Plex.
I can also do a scan in plex, but the end result is the same…No channels found ?? :frowning:
Yep - Emby see all channels just fine :frowning:
i have the same problem here in switzerland. i can’t change to DVB-C. :frowning:
Same for me here in Belgium, I have DVBSky t680c tv tuner with DVB-C and only DVB-T is showing up, anyone got this resolved?
Anyone ever found a solution?
Sorry, but no :frowning:
I had to take the best part of two worlds in order to satisfy the family:
  • Emby for viewing and recording TV (with a script for tv-guide which Emby handles quite well)
  • Plex for viewing movies and all other stuff (exempt TV which a mediacenter should be able to handle)
