HDHR3-US can't be added to docker
Server Version#: 1.18.2.2058
Running via Docker Compose
I have an HDHR Extend as well as the HDHR Dual. When I go to add the DVR, it finds the extend without a problem. However, the Dual is not found, even when providing the IP address.
I’m currently running PMS in Host mode just to try and figure out what is happening. I don’t believe this is a networking issue.
I am hoping there a way to manually add the missing tuner.
What else should I be checking for in the logs?
Is this not supported anymore?
