Server Version#: 1.19.4.2902
Tuner Make/Model: HDHomeRun Connect Quatro HDVR-4US-1TB
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Issue:
I had the liveTV setup and working for more than 4 months. I tried to record an OTA show recently and it said the server was unavailable so I tried to go to the liveTV on the android app as well as the full web version and the LiveTV does not show up as a viewing option. When I go to check the status of the tuner from Plex it has the setup as if it isn’t setup anymore. When I try to add the tuner it does not find it and when I try to add it manually it does nothing. Looking at the logs it shows this:
device://tv.plex.grabbers.hdhomerun/152045DE at http://192.168.1.69:80
Jun 09, 2020 08:20:21.978 [2052] Debug — HTTP requesting GET http://192.168.1.69:80/discover.json
Jun 09, 2020 08:20:21.984 [2052] Debug — HTTP 200 response from GET http://192.168.1.69:80/discover.json
Jun 09, 2020 08:20:21.984 [2052] Debug — HTTP requesting GET http://192.168.1.69:80/lineup_status.json
Jun 09, 2020 08:20:21.996 [2052] Debug — HTTP 200 response from GET http://192.168.1.69:80/lineup_status.json
Jun 09, 2020 08:20:33.509 [0424] Debug — Request: [192.168.1.105:64569 (Subnet)] POST /media/grabbers/tv.plex.grabbers.hdhomerun/devices?uri=192.168.1.69 (11 live) TLS GZIP Signed-in Token (#####)
Jun 09, 2020 08:20:33.509 [0424] Debug — Grabber: Checking device URI http://192.168.1.69
Jun 09, 2020 08:20:33.509 [0424] Debug — HTTP requesting GET http://192.168.1.69/discover.json
Jun 09, 2020 08:20:33.514 [0424] Debug — HTTP 200 response from GET http://192.168.1.69/discover.json
Jun 09, 2020 08:20:33.514 [0424] Debug — HTTP requesting GET http://192.168.1.69/lineup_status.json
Jun 09, 2020 08:20:33.526 [0424] Debug — HTTP 200 response from GET http://192.168.1.69/lineup_status.json
Jun 09, 2020 08:20:33.557 [0424] Debug — Grabber: tv.plex.grabbers.hdhomerun called the probe of http://192.168.1.69 a success.
Jun 09, 2020 08:20:33.557 [0424] Debug — HTTP requesting GET http://192.168.1.69/discover.json
Jun 09, 2020 08:20:33.564 [0424] Debug — HTTP 200 response from GET http://192.168.1.69/discover.json
Jun 09, 2020 08:20:33.564 [0424] Debug — HTTP requesting GET http://192.168.1.69/lineup_status.json
Jun 09, 2020 08:20:33.576 [0424] Debug — HTTP 200 response from GET http://192.168.1.69/lineup_status.json
Jun 09, 2020 08:20:33.604 [0424] Info — Grabber: The device was already discovered at http://192.168.1.69, updating URI
Jun 09, 2020 08:20:33.606 [4204] Debug — Completed: [192.168.1.105:64569] 200 POST /media/grabbers/tv.plex.grabbers.hdhomerun/devices?uri=192.168.1.69 (11 live) TLS GZIP 96ms 940 bytes (pipelined: 31)
I can supply more logs if needed. As you can see it says that it is already discovered but does not add tuner. Can confirm it is not recording from Plex and I can get to the tuner via http.
