HDR Filter not find movies in bt2020 colour space
Server Version#: 1.20.4.3517
On an earlier question I raised, it was suggested to me that the HDR filter built into Plex was a good way to find all HDR movies in the library. Now though that did not quite do what I required, I did have a play with it.
In the process, I found it would not find all movies that I thought would be captured. Here is info from a movie I thought would be filtered as HDR.
Is it right that this media was not flagged as HDR by Plex?
Codec HEVC
Bitrate 15971 kbps
Bit Depth 10
Chroma Subsampling 4:2:0
Coded Height 1608
Coded Width 3840
Color Primaries bt2020
Color Range tv
Color Space bt2020nc <— HDR?
Color Trc smpte2084
Frame Rate 23.976 fps
Height 1608
Level 5.0
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K (HEVC Main 10 HDR) <— HDR?
Extended Display Title 4K (HEVC Main 10 HDR) <— HDR?
any thoughts?
The movie example above does not show when I filter a library using the HDR default filter
No ideas? :roll_eyes:
Does anyone have issues with the Plex HDR filter flag not picking up HDR content?
I cannot remember which version but a Nov/Dec release of PMS had in its release notes a [FIX] for HDR tagging. So though there was no reply here, someone might have seen this and acted upon it!
