Headless Plexamp for 64 bit system
Hey guys,
Is it possible to have a version of the new Plexamp (v2.0) that runs on larger systems than a raspberry pi?
I’m running a headless Debian server and would like to use Plexamp.
With the first version of Plexamp for Raspberry Pi I was able to tinker around with it and make it work for me. Now I thought I’d try upgrading to the new release, which breaks my setup.
I reinstalled the node modules since it looked like the ones packaged in the download where not compatible with a 64bit system. And now I’m getting the following error.
c.AudioPlayer is not a constructor
for the file ../plexamp/server/server.prod.js
any one have any suggestions? Or @elan is there another version in the making?
We may offer a 64-bit ARM version in the future, if that’s what you mean?
Ah, I think you mean a headless Intel version; that’s a possibility as well.
Wasn’t sure if it made a difference, since I got the previous version to run.
But yes, a headless Intel version would great :slight_smile:
Same! I’d love to run Plexamp on my (Intel) home server alongside Snapcast.
