Okay I started checking the version numbers but PMS kept crashing. Apple Movie Trailers appeared to be the biggest problem causing it to crash PMS 100% of the time. I'll continue checking and report back
With the Colbert Report it is not a matter of files being in parts, the actual Full Episode menu or Tab is missing from the interface on Plexconnect while it is there in Plex iOS client.
Apple movie trailers channel is broken by PlexConnect so it will never work with the current architecture.
I don't mean in the UI ;)
Sometimes the channel devs hide what is really going on underneath.
Here you go:
http://forums.plexapp.com/index.php/topic/48272-daily-show-on-roku-not-showing-full-episodes
The client needs to account for and hide the splitting, usually due to ad breaks.
AMAZING!!
Letmewatchthis and Icefilms are working :)
Thank you !
Wow. What did you do?
Letmewatchthis, SSPlex, Icefilms, MSNBC, NBC, ABC all work now. I am amazed. Also, Colbert and Stewart have the full episode tab!
The only two channels that I tried that don’t work are CBC (Canadian Broadcasting Corporation) and the Food Network. Both of these throw up the “trailers is unavailable” error.
I’m flabbergasted.
ssplex doesn't work for me .
Update- Now its working i unchecked avoid flv files now its all good
avoid flv files? in PMS?
Wow. What did you do? ... I'm flabbergasted.
Well, Live goes on... flabber-what?
:-D
Baa, avoid flv is a setting in the SsPlex plugin.
flab·ber·gast (flbr-gst)
tr.v. flab·ber·gast·ed, flab·ber·gast·ing, flab·ber·gasts
To cause to be overcome with astonishment; astound. See Synonyms at surprise.
[Origin unknown.]
institue11:
But Colbert wouldn't play the full episodes, would it?
Appears not, unless the full episode is 9:23 long
Update on our earlier post of 9 out of 27 Channel's working. Again our setup is an aTV that was updated to v.5.3, we have latest build of PlexConnect downloaded at 11:15 ET today (6/30). PlexConnect is installed on MAC Mini Server (OSX v.10.8.4), using our own DNS, WebServer is provided by PlexConnect on port 9999.
- Two MAC's running Plex Media Manager (v.0.9.5.4).
- Mac Mini running latest version of Plex Media Server (v.0.9.7.22.511-4b5280f-OSX).
- All aTV tests were done using play button, not center key on aTV remote
- aTV "ForceDirectPlay" setting set to "True".
- Full PlexConnect.log file can be viewed via: http://pastebin.com/wTHyg8AZ
- ABC
- CNN - Other than "! An error occurred loading this content." on Live, Weather, other clips seem to work.
- NASA
- National Geographic
- NBC
- TED Talks - Sometimes get "! An error occurred loading this content."; however most other clips work
- MSNBC
- A&E
- CBS
- Food Network
- HGTV
- The CW
- The WB
- The White House
- CBS Sports
- Comedians in Cars Getting Coffee
- Comedy Central
- Fox News
- The Onion
- Hulu - This is an Issue for me as I don't subscribe to Hulu Plus, so I can't use native aTV app.
- Netflix - No big deal as I can use native aTV app.
For me channels that now work for the most part, that did not before today:
LetMeWatchThis
Icefilms
SSplex
NBC
ABC
Crackle
MSNBC ("latest full episode" link works but not others)
TedTalks
For the first three, the search function doesn't work but I am sure that is an ATV firmware limitation, just as you cannot set preferences in channels on Plexconnect. Crackle today allowed me to see only certain categories but it let me play sources that were available. Also, the IOS Plex Client had the same issues with Crackle.
These join the following channels as working for me:
YouTube
Ustream
Twit tv
PBS
Justin TV
History channel (us)
Funny or die
Imdb trailers (a bit flakey but usually works)
Colbert (only shows 1/3 of full episodes)
Daily show (only shows 1/3 of full episodes)
Also, Hulu doesn't work on any of the clients at the moment although people are working on it. I will make a list of channels that don't work over the next couple of days, comparing them to iOS as I go. BBC Player is one I would like to get working.
IceFilms still doesn’t work, nor does LetMeWatchThis/ SS Plex. How are these working for other people? Getting: “No response from PMS,” or “Trailers is Unavailable. Try Again.” Running latest version of everything. Mac OS X, aTV3, plexpass beta PMS, newest build of PlexConnect…
I’m watching Spider-Man (2012) in HD on Plexconnect via Icefilms right now.
Restarting PMS made it work. Sweet!
Glad to hear it.
