ICEFILMS and filmon seems to be work but when going to preferences trailers is nuavailble and when trying to watch any video this error:
plex connect
no response from plex media server
help me please !
thank you
plex connect
help me please !
thank you
OH, this is my log:
Log doesn't really help.
Do you have the latest sources?
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):3
5.3
The DNS server set on the ATV (found under the ATV settings > general > network > DNS):192.168.1.16
The device and operating system (including version number) that PlexConnect is installed on:imac os x 10.8.4
The local IP address of the device that PlexConnect is installed on:192.16.8.1.16
The device and operating system (including version number) that the Plex media server (PMS) is installed on:imac os x 10.8.4
The Plex media server (PMS) version number you are running (**do not put 'latest'**):0.9.7.28.33
The local IP address of the device that the Plex media server (PMS) is installed on:192.168.1.16
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.
newest release, an hour ago downloaded, the problem since ever
The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 8.8.8.8
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
ip_pms = 192.168.1.16
port_webserver = 80
Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this to http://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space):i don't know what format it is, it's movies from icefilms and filmon that there channels work in plexconnect for everybody else by what i read today.
A detailed description of the issue (the clearer you can make this the better):the main post.
Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one:
i think. i have the last plexconnect, downloaded an hour ago. 5.3 version on atv3. both icefilms and filmon channels downloaded from unsupported Appstore. isn't it the newest there ?
PlexConnect should be fine then. iBaa branch, right?
As for those plugins, I can't say. I have no idea what they do/where to get the latest from. Other than (maybe) https://github.com/plexinc-plugins. But those are probably the "supported" ones.
thanks. this is weird. i click on update in the unsupported appstore and it started working, but only icefilms.
filmon still gives me plexconnect no comment from plex media server when trying to access things
for example
channels>filmon>tv shows>popular>error
i can be only at the main menu or the one after it, any menu after that gives the error.
and is there a way to download a subtitle from the internet when seeing movies in icefilms/filmon ? is there a plugin for that ?
weird, i didn't think channels updating hourly.
i installed ssplex and i can't do some actions like search (same plexconnect no comment from plex media server error)
and is there a plugin that i can add subtitles while watching a movie in icefilms or channel like that ?
You are correct that search does not work in icefilms or letmewatchthis but at least the videos play now.
In Plex iOS Client, an iOS dialogue box pops up for these channels which you then type the search term in. Maybe this confounds the ATV.
Can’t help you with subtitles. Try doing some research in the Plex Channel forum.
You are correct that search does not work in icefilms or letmewatchthis but at least the videos play now. In Plex iOS Client, an iOS dialogue box pops up for these channels which you then type the search term in. Maybe this confounds the ATV. Can't help you with subtitles. Try doing some research in the Plex Channel forum.
ok so why any video in filmon doesn't play ?
and is there a solution for search ? search is everything after all
FilmOn? Let me have a look.
Where is this plugin from? I have never seen it, nor did a quick search bring meaningful results...
Currently the only solution is to search in another Plex client on your computer or the iOS client and save what you find in favorites. Then access favorites in Plexconnect.
Whether or not search can be implemented in Plexconnect itself I will leave to the developers to address. I think we should be appreciative of what marvels they have wrought for us up to this point, and not be too demanding.
As for FilmOn, I don’t have it installed.
it's plugin name is letmewatchthis and it's availble in unsupported appstore channel
Currently the only solution is to search in another Plex client on your computer or the iOS client and save what you find in favorites. Then access favorites in Plexconnect. Whether or not search can be implemented in Plexconnect itself I will leave to the developers to address. I think we should be appreciative of what marvels they have wrought for us up to this point, and not be too demanding. As for FilmOn, I don't have it installed.
ok
i can't do anything with those feature without subtitles anyway so thanks ..
Locked for cross posting.
Also you will NOT be able to download and inject subtitles on the fly into channels.
