2 days ago everything was fine - when i open mt Tv today got a new version of plex , but my hebrew subtitles are reversed punctuation( ON MY PLEX SERVER on my pc the subtitle are fine )
and when i search for a movie subtitle search i cant select hebrew language has i could before that version
everything was perfect before … please HELP
Server Version#: 4.34.3
Samsung TV 65INCH 4K
Client Version#: 5.1.2
platform Version 4
Same issue for me, right after the update of Plex on my samsung TV two days ago.
I update the pc with the latest plex server version and latest plex windows version
but this does not help…
i pretty sure its the new update from plex app Samasung tv , because at my plex server NAS everything is fine …
i really hope they will fix that or downgrade the version
Thanks for the report. I’m looking through this issue now and trying to reproduce the problem, but I’m not seeing the issue here (of course, I can’t read any RTL languages so I could be wrong). Could I get some logs to help track down this issue? Even better would be a sample subtitle file, with examples of how it should look and how it’s being displayed.
Thanks, I can see the issue with your sample, but I am unable to reproduce the issue on my devices. Could you provide a sample .srt file that is causing the problem?
Just to confirm, when you are having the RTL issues, is the Subtitle setting on the info screen set to AppRenders or ServerRenders? Also, is it direct playing/streaming or transcoding the video?
In your screenshot, is the subtitles correct? It looks like the punctuation is in the correct spot to me. Also using your sample on the early access app, the non-early access app, and the desktop app all yields the same result for me. What model is your TV? Maybe you can grab some logs as well with the issue, hopefully that’ll give us something to look at. You will need to enable Settings -> Advanced -> Log to Media Server to make sure your device generates logs.
The subtitle is not correct in my screenshot although punctuation seems in the right place.
TV model is Samsung Q6FN (TIZEN 4)
Attached are logsPlex Media Server Logs_2020-09-26_11-00-26.zip (611.3 KB)
