Held transaction for too long - StatisticsManager.cpp keeps increasing
any ideas @ChuckPa ?
you are having some serious problems with that host.
May 23, 2024 10:55:27.532 [23055675833144] ERROR - Caught exception trying to stream file: /transcode/Transcode/Sessions/plex-transcode-wwd6abv17tlag10lwvnk3d24-b2e44f60-2c13-4785-b501-208e5c647668/init-stream0.m4s,/transcode/Transcode/Sessions/plex-transcode-wwd6abv17tlag10lwvnk3d24-b2e44f60-2c13-4785-b501-208e5c647668/chunk-stream0-00029.m4s: write: protocol is shutdown (SSL routines) [asio.ssl:167772367]
Your LAN is IPv4. Please go into Settings - Server - Network - Show Advanced.
Turn off IPv6 support. It’s causing issue.
ALSO tell everyone who streams from you to restart their player apps and update your server’s certificate info.
May 23, 2024 11:26:36.442 [23055977876280] DEBUG - Auth: authenticated user 131763859 as Mario Ozuna
May 23, 2024 11:26:37.117 [23055979985720] WARN - [CERT] TLS connection from [::ffff:31.27.4.133]:64457 came in with unrecognized plex.direct SNI name ‘67-175-35-0.e00822b8d03a42279688f2ea605ca556.plex.direct’; using installed plex.direct cert
May 23, 2024 11:26:37.252 [23055977876280] DEBUG - CERT: incomplete TLS handshake from [::ffff:31.27.4.133]:64457: sslv3 alert certificate unknown (SSL routines)
May 23, 2024 11:26:42.467 [23055977876280] WARN - [CERT] TLS connection from [::ffff:31.27.4.133]:64458 came in with unrecognized plex.direct SNI name ‘67-175-35-0.e00822b8d03a42279688f2ea605ca556.plex.direct’; using installed plex.direct cert
May 23, 2024 11:26:42.473 [23055977876280] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
May 23, 2024 11:26:42.473 [23055977876280] DEBUG - [HCl#364d] HTTP requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&unknownToken=xxxxxxxxxxxxxxxxxxxx
May 23, 2024 11:26:42.733 [23055979985720] DEBUG - CERT: incomplete TLS handshake from [::ffff:31.27.4.133]:64458: sslv3 alert certificate unknown (SSL routines)
May 23, 2024 11:26:42.946 [23055910816568] DEBUG - [HttpClient/HCl#364d] HTTP/2.0 (0.5s) 200 response from GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&unknownToken=xxxxxxxxxxxxxxxxxxxx (reused)
May 23, 2024 11:26:42.948 [23055977876280] DEBUG - MyPlex: updating with 126 access tokens
Also, check the host network configuration, Turn off IPv6 (set 'disabled).
embarrassing… when I created the new dataset, it was on the array, 1 flash drive. moved it to the zpool and everything is running great with @ChuckPa’s advice. :slight_smile:
