Help just changed router and can't access Plexconnect anymore
I have recently changed router and DCHP addresses changed as a result but i can't access from my ATV2 anymore the server i have installed on my mac mini. Server is with a static ip (192.168.1.101) which is different to the previous one (192.168.2.101), and using Plexconnect. Everything was working perfectly till i changed the router where all devices are connected to (mac mini, ATV2 via wireless etc.).Is this creating the problem or anything else i need to look for?
PlexConnect on aTV? Or MacMini? IP of aTV?
Did you change DNS IP on aTV already?
Log? Might not show much, but an overview of the used addresses...
We need more details to help.
I'm accessing Plexconnect on MacMini via the Trailers app on Apple TV 2nd generation (ATV2 hacked). Macmini IP is static 192.168.1.101, have changed on ATV2  DNS settings to manual to the same IP but still no joy...ATV2 IP is showing DCHP 192.168.1.12. How can i get a log?
Plexconnect.log is in your Plexconnect directory
Also post your settings.cfg file
Sorry found it, for some reason it had still the settings/IP from the previous DNS...once i changed that it's working again. Many thanx for the help.
